1972 Door Edge Molding Placement
Old Nov 2, 2013 | 02:48 PM
Mortimer's Avatar
I just received the door edge molding for my 1972 Cutlass Supreme 442 Convertible. Problem is where exactly does it go? It does not fit the entire door but only a portion. Is ther a guide to tell me whre the top and bottom of the edge molding goes? Don't want to tear up the paint job while experimenting.
Please help!!!!!!!
Old Nov 2, 2013 | 06:17 PM
I bought a set for my 71 also but am afraid to put on because I may damage paint. Mine are metal repops that appear to fit only one way because of the contour, I think they will only go on in one place. Do you have a set of plastic universal door edges? Hopefully someone who has installed them will chime in.
Old Nov 2, 2013 | 06:49 PM
2blu442's Avatar
OK, here's the trim piece I think your asking about. If I'm on the wrong track let me know. The photos are of a 1971 Cutlass Supreme door, and the door edge trim is about 4 inches from the bottom, and about 2 1/2" from the top inside edge. Let me know if you need to see any other views. John
Old Nov 3, 2013 | 06:28 AM
Mortimer's Avatar
2blu442,
You are a lifesaver. 4" from the bottom worked perfectly. Bit nerve wracking as these metal edge moldings want to peel the paint as you install but they are in place and look great.
Thanks for the help.
Old Nov 3, 2013 | 06:47 AM
2blu442's Avatar
Cool! I'm glad it worked out well.
John
Old Nov 3, 2013 | 07:05 AM
Mortimer's Avatar
Greg,
I just installed my metal door edge guards. Used 2blu442 measurements, decided which molding went to which door and carefully used rubber mallet. Started at the bottom and worked my way up, slowly. Yes, there was a bit of scratching. After installation used Meguiar's Scratch X20 and removed all traces of installation.
Worked for me! Good Luck.
Old Nov 9, 2013 | 07:47 PM
Great! thanks to you both! I will install mine next spring.
Greg Rogers
Body work
Feb 5, 2013 08:46 PM
hinz57
Jan 23, 2013 01:03 PM
davesdelta
Feb 20, 2012 04:33 PM
w-30dreamin
Jun 24, 2010 12:41 PM
BR[]
Apr 22, 2009 06:00 PM
