1969 fact search
1969 fact search
Hello All, as 69Cuttynoob, this is my first post and introduction. I'm looking for research help with a recent purchase. It’s a 1969 Oldsmobile Cutlass S Convertible in much need of repair; it has a 4 speed manual transmission with Hurst badges on the shifter stick and console. Appears to have dual exhaust but has a 2 barrel carburetor. I’m trying to determine what is the numbers matching engine code is installed. Thank you all in advance for your assistance. Once I figure out to upload pictures I will. I've spent the first 4 days cleaning out the numerous rodent nests and getting to know my new project. I've had many other projects in the past but this is not only my first Convertible but my first Oldsmobile. Looking forward to tapping the vast knowledge base provided here.
It will be 3 (for Oldsmobile), 9 (for 1969), M (or a different letter, indicating the assembly plant), and then xxxxxx, which will match the last six digits of the VIN.
39Mxxxxxx
Welcome to ClassicOlds.
Welcome. The factory shifter should have the "HURST" name stamped on the stick, but there were no other Hurst badges on the car. Any that are there now were added by a previous owner. Regular production option (RPO) N10 Dual Exhaust was a $30.28 option available on any V8 Cutlass S that year, including 2bbl motors.
Ah yes! I found it! Thanks. Yes it matches the VIN so that's a good start. I've seen talk about "W" engine codes W30, W31 & W32. Is that indicated anywhere on the engine or block? Again thanks for the tip!!
Thanks Joe! There is only one other "H" Hurst indicator inside the car, it's embossed on the rubber boot attached to the center console between the seats. Cracked and looking brittle but you can still see the “H”.
And no, there are no indications on the block of W-ness. If you have to ask, it almost certainly is not a W-31.
Hurst Shifter Q&A
Hey Joe, I wanted to upload a picture of the shifter but not having any luck. I hope this works Shifter.jpg. If not I'll try again.
XG = M20 Wide Ratio
XF = M21 Close Ratio
I don't think they put the VIN derivative on the manual transmission but have a look. It might look similar to this MT (pic taken from Chevy Forum)
(not to be confused with the intake or head castings)Go to this link How To Post Pictures
Ok, here's what it means
ST69 - 1969 model year production
3 - Oldsmobile Division of GM
36 - Model: Cutlass S
67 - Body type: Convertible
LAN - Body Shell produced by Lansing Fisher Body Works (different from final assembly)
BDY 273217 - Body number assigned by FBW. Not related to VIN.
TR 937 - Interior trim style and color - Antique Parchment
PNT 59 A Lower body color: Meadow Green. White (A) vert top
01E - Time build at FBW: 5th week (E) of January (01) 1969
Thanks you guys! I tell you this site and it's members are better than Google! You would not believe the stuff that comes up when I search things like "Cam duration" or "Crank Shaft". Disturbing.
Your computer must have a virus or malware. I googled that and got exactly what I expected - mechanical information about crankshafts and cam duration...
You didn't hit "I feel lucky" when you did the search by chance, did you??? That would likely take you somewhere you don't want to go.
Google is "adaptive," Allan, and tailors its searches based on things that the user has searched for in the past, so... You may search for different types of things than he does...
Presumably (and I have seen no evidence for this), the tubes were numbered sequentially as the blocks came down the line at a specific point, and those numbers were used internally to monitor quality, linked back to the plant, machines, and workers who produced the actual engine, so that if a pattern of problems emerged (specific casting flaw, specific loose bolt, etc) they could track it back and find the source.
If they kept any records beyond the first year or two, it does not appear that anyone is aware of their existence.
It's as good a theory as any I've ever heard. Agreed that record keeping is a great hindsight. Unfortunate situation. Wonder why Olds never kept the records that Chev, Pontiac and Buick did. A ponder for another thread I think.
what is it
As most of you know I've been working on inventorying everything that came with my new project and ran across this thing. I don’t even know if this is part of my 1969 Cutlass so I’m putting it to the group for review. The question for today is “Whaaaat is it”
[QUOTE=69Cuttynoob;859353 I don’t even know if this is part of my 1969 Cutlass so I’m putting it to the group for review. The question for today is “Whaaaat is it”[/QUOTE]May I suggest you provide a 'scale' for measuring the size of that piece? Can't tell anything about it's dimensions from that pic.
What is it
Although I think it would be cool to have a wheel chair access in a 1969 Cutlass but I was told “Don’t throw anything away until you know what it is and don’t need it. I was thinking that it might be a cover for the hydraulic motor for the top but I can’t find any references. Here is another picture with dimensional references.
Or a small generator tray for an RV. But kinda light gauge metal for either options mentioned. Maybe a 1-2K gen set at best. Or a midget wheelchair ramp...oops sorry I meant to say a smaller persons chair. The mystery continues....An thats a nice shot of an original floor pan for a stick.
