1966 442 front drum wheel stud
Old Apr 5, 2014 | 08:27 AM
kelly bakies's Avatar
I am missing one wheel stud and everything I am finding at the parts store are not correct. The hole for the knurled is a .6 of a inch, the wheel stud at the parts store is a .555 of a inch. It falls in the hole. Anybody out there with any knowledge of where I can find the correct stud.
Appreciate any and all help.
Kelly
Old Apr 5, 2014 | 10:47 AM
Kelly
The Dorman catalog (available on-line in PDF form) lists dozens of different wheel studs with dimensional info. Pick one that works. I had to do this with my 62.
Old Apr 5, 2014 | 03:10 PM
dorman
I have been there and nothing is corret. I plan on calling them direct monday.
Kelly
Old Apr 5, 2014 | 03:55 PM
Kelly
You're right - I just looked myself. A 0.6" hole tells me that someone has stripped the knurl. I've had this problem in the past and I just tack welded the stud to the back side of the hub. If the 0.555" knurl is so loose it wobbles, I'd consider one of the Dorman studs with the 0.575" knurl and then tack weld. The alternative is a replacement hub.
Old Apr 6, 2014 | 07:38 AM
all the same
The hole is not stripped or been drilled. I can measure the other studs coming out the edge of hole and you can measure they are bigger. I am considering getting a 1/2" stud and grind the threads off and tap it. It has a bigger knurl area.
Kelly
matviar
Oct 22, 2014 11:12 PM
EightballZ
Mar 24, 2014 05:03 PM
455Olds
Brakes/Hydraulic Systems
Dec 8, 2013 08:16 PM
Oldssupreme
Jan 29, 2013 07:03 PM
1carsick
23
Oct 2, 2012 05:50 PM
