1965 f85 cutlass
Old Apr 3, 2012 | 11:53 PM
oldstata's Avatar
Justin
1965 f85 cutlass
I am not sure how to tell if my car is a true cutlass or the f 85 the dash says cutlass and the right fender has a cutlass tag the rear trim plate has f85 and the left front fender has the v 8 tage not really sure if there are other clues or if there all just the same any help would love to learn more about this car
Old Apr 4, 2012 | 06:28 AM
stan 65 cutlass's Avatar
is it a hardtop? (no post when windows rolled down)
all hardtops were cutlass'
can you post a pic of your data tag?
Old Apr 4, 2012 | 06:31 AM
these style codes are cutlass only
CUTLASS
Sports Coupe ( post ) .......................................... 3827
Holiday Coupe .................................................. . 3837
Convertible .................................................. ...... 3867
taken from http://www.442bro.com/
Old Apr 4, 2012 | 06:56 AM
64 convertible yaman's Avatar
yaman 64
Question F-85/ Cutlass
Good day
Well i have a 1964 and and it's both? 1964 cutlass F-85
I know in 64 i believe they didn't have it all together with the new models so mine is badge both for some reason and after reading have not found another reason.
Mine was build in canada.
Old Apr 4, 2012 | 07:14 AM
they are all f85, cutlass is the top of the heap as far as interior and chrome, mine is also canadian, some slight differences to our southern built cars
Old Apr 4, 2012 | 07:22 AM
oldstata's Avatar
Justin
Yes it's a hard top is the data tag the one in the engine area so witch tag should be on the fender the cutlass or the v 8 or did they put non matching tags ?
Old Apr 4, 2012 | 07:27 AM
Fenders, emblems, etc could have been changed over the last FOURTY SEVEN years due to accidents or rust. The VIN will tell you exactly what it is.
Old Apr 4, 2012 | 07:36 AM
Cutlass Brazil's Avatar
I have a very similar 1965 vehicle, convertible, provincial white, 330 cid, jet-a-way automatic, and it´s classified as an authentic Cutlass F -85. The VIN and body tag will tell you for sure.
Old Apr 4, 2012 | 08:12 AM
yaman 64
65 f-85
Hay Stan Are you up on Canadian built?
I have yet to decifer the body tags on my 64 convertible.
I have to pics up on here for all to see it's a driver that needs our attention.Whats the easiest way to post pics?
i believe your car should have cutlass tags on the fenders, f 85 cutlass on dash, cutlass on rear panel,
Old Apr 4, 2012 | 08:16 AM
64 is slightly different on some codes, for pics i use photobucket and a complicated method, i believe there is an easier way straight from your computer, maybe someone will chime in then we will both know
Old Apr 4, 2012 | 08:19 AM
best way is to send in your vin to get decoded at gm historical services
George Zapora
General Motors of Canada
Vintage Vehicle Services
CA1-160-001
1908 Colonel Sam Drive
Oshawa, ON
Canada L1H 8P7
Phone: 905-440-7636
Fax: 905-440-7644
Old Apr 4, 2012 | 08:24 AM
yaman 64
65 f-85
Thanks Stan i will do that.
Then i will know for sure.
Old Apr 4, 2012 | 08:29 AM
in the meantime we can take a poke at your codes,
have a look on here
and on here
http://ultra-high-compression.com/
Old Apr 4, 2012 | 08:38 PM
oldstata's Avatar
Justin
The code is3827
La 20962 s
301110
Old Apr 5, 2012 | 04:34 AM
yaman 64
Good Morning:
Sorry Stan had to step out yesterday.
This is what i have.
Vin# -is eleven dijit number
Front engine bay tag.
Style 3276 1-12-17
Body No- 352122
Paint- V
Trim- 965
M33 T10
This is what i have on my fire wall tag.
The 65 info does not jive with the 64 stuff that i could fine anyhow.
Old Apr 5, 2012 | 08:39 AM
George Zapora
CA1-160-001
Oshawa, ON
Canada L1H 8P7
Phone: 905-440-7636
Fax: 905-440-7644
Unfortunately that only works for a car that was either built in or originally sold in Canada. The OP shows Utah as a location, so I suspect this is not a Canadian car.
Old Apr 5, 2012 | 09:44 AM
that was in response to 64 vert yaman's question
Old Apr 5, 2012 | 11:04 AM
Originally Posted by 64 convertible yaman
Good Morning:
Style 3276 1-12-17
Body No- 352122
Paint- V
Trim- 965
M33 T10
i got a few of em,
3267 convertible
1 12 17 1st shift dec 17
paint v ember red
trim 965 (interior) hol red
m33 2 speed jetaway with variable vanes
Old Apr 5, 2012 | 11:15 AM
The code is3827
La 20962 s
301110
3827 cutlass sport coupe post
??????? need more info
Old Apr 5, 2012 | 11:33 AM
oldstata's Avatar
Justin
It was sold in Ogden Utah new on the lot the owner I bought it from past away and his grand son sold me the car he owned it for thirty years Not sure of the history before that
Old Apr 5, 2012 | 11:34 AM
could you copy down all info from data tag under hood?
Old Apr 5, 2012 | 12:28 PM
oldstata's Avatar
Justin
07a. S
St 65-33827 lan20962
Tr 303-a. D-D
W 2K
Old Apr 5, 2012 | 12:56 PM
07a. S
Tr 303-a. D-D
W 2K
07 a, build date 1st week july
65 33827 65 cutlass sport coupe post
tr3o3a dd blue interior , bench seat, paint lucerne mist upper and lower body
w 2k tinted windshield, firewall piercing air conditioning
i think thats rite?
Old Apr 5, 2012 | 01:44 PM
oldstata's Avatar
Justin
What's fire wall piercing?
Old Apr 5, 2012 | 02:09 PM
the factory would have to pierce (cut a hole) in the firewall for air conditioning
BIGBAD455
Cars Wanted
Feb 1, 2010 07:17 PM
seymog
Dec 23, 2009 09:23 AM
65az
Nov 21, 2009 11:49 AM
clip74
Oct 31, 2009 09:09 PM
ProPain
Mar 30, 2009 06:56 PM
