No-holes fire extinguisher mounting bracket
Old Nov 26, 2020 | 10:15 PM
Jon442's Avatar
Gearhead
I wanted to mount my halon fire extinguisher in my car, but didn't want to drill any holes. It's large enough that the only practical place to put it is in the back seat floor board. I ended up making brackets with my 3D printer that worked great. I thought I would share this with the forum and offer them for sale.
These brackets are designed for 1968 - 1972 A-body cars, but may fit other models as well. The brackets are made from a material called PETG, which is used to make 2 liter pop bottles. The PETG that I use for these brackets is also infused with carbon fiber. They are very light but very strong and are more than adequate to hold up to a 2.5 pound fire extinguisher, which is what I have. The only drawback is that PETG starts to melt around 175 degrees F, so if you live in a climate where your car sees those kind of temps in the interior, this may not work.
Here is what the bracket looks like, with the fire extinguisher bracket mounted to it:
Here is what it looks like mounted in the car:
The upper bracket is made to slip inside the rear seat mounting bracket. A bolt runs thru the seat bracket and fire extinguisher bracket to hold it in place. No drilling!
I have made a bracket that is somewhat universal and should fit various fire extinguisher brackets. Here are the measurements of the holes. The rectangular mounting portion of the bracket measures 165 mm x 36 mm. You would need to drill the two lower outside holes, if desired:
I have also made a blank bracket, for which you will need to drill your own mounting holes:
The width of the upper bracket (the one that fits within the seat mounting bracket) is 11 mm. The seat bracket it's designed for looks like this:
I'm selling the bracket kit, which includes two 3D printed brackets, for $20 shipped within the US. If you wish to buy one, please PM me. Please measure your fire extinguisher bracket and make sure it fits, or order the blank bracket.
Old Dec 21, 2020 | 12:52 PM
jerry63's Avatar
Halon is designed to be used within an enclosed space, (engine compartment of a boat), It is not designed to be used as a regular fire extinguisher
Old Dec 21, 2020 | 02:10 PM
Jon442's Avatar
Gearhead
Halotron I, which is what I use, is suitable and recommended for automobile fires.
Old Dec 21, 2020 | 07:19 PM
green1972's Avatar
I bought this extinguisher last year and like your set up, I'll take one, pm Me how to pay
Old Dec 22, 2020 | 05:28 AM
jerry63's Avatar
I stand corrected, You stated Halon, not halotron 1, I had a Halon system in my engine compartment of my boat.
Old Dec 22, 2020 | 04:30 PM
bronze66f85's Avatar
PM sent
Old Dec 23, 2020 | 06:28 AM
Jon442's Avatar
Gearhead
Just to clarify, I provide the two black 3D printed pieces shown in the first photo. You will need to provide the metal fire extinguisher bracket and any hardware.
Old Feb 8, 2021 | 05:56 AM
Jon442's Avatar
Gearhead
Bump for car show season coming up.
Hairy Olds
Sep 13, 2020 03:40 PM
Hairy Olds
Jan 3, 2020 06:29 PM
Jan Olaf Hansen
Mar 25, 2019 02:54 AM
Jaybird
Dec 28, 2011 08:46 PM
442much
Feb 2, 2011 08:16 AM
