FS: Olds engine cradle. $55 USD
Olds engine cradle from Jeg’s. Bought 2 weeks ago to transport my engine to the dyno. No longer need it. Modified to fit engine with flywheel, starter and exhaust manifolds on. This way you don’t have to take your engine apart to transport it. Cost me
$77 on sale, will sell for $55 USD. Cradle is in Omaha, NE. Frank, 402-393-5252, fpcopo@***.net.
I shortened the two brackets that bolted in the motor mount holes so the starter could stay on. I cut the other side because 3 bolts on a side was overkill. I also notched the right rear bracket inside and out so it would clear the starter ring gear and stock exhaust manifold.
