Enclosed Car Trailer Wanted
Looking for a used enclosed car trailer. Must be at least 20' long and in like new condition. Want to see if I can get a good deal on a used one before I spring for a new one.
Thanks,
Thanks,
Escape door...nice!
Those long lines are not scratches, just reflections
Brand new Goodyear tires
Bonus door/ramp for motorcycles/ATVs
Plenty or grease on all the bearings. Brakes had no linings left.....completetly destroyed. I bought 4-new brake kits that included the backing plate with everythng already assembled and hubs.
This is why easy lube axles are not always a great idea. Seller said he always kept up on maintaining grease in axles. Obviously if he would have had to pull the hubs off he would have noticed the brakes were missing!!
More brake destruction
Needs a little claening and paint. No water leaks so far.
Will make for some nice overflow storage....
All in all I'm happy witth the purchase. Paid $4k for the trailer and another $950 for brakes, hubs, battery and break away switch. It will be used sparingly so it should last as long as I'm around.
Found what was left of this shoe in one of the drums
I was wondering about that - hooking (syncing) up your truck brake controller. You probably didn’t have far to run or were pretty much straight-lining it because had you done any hard stops or downhills you would have surely known there weren’t any brakes in that baby. That’s kinda funny. I’m sure your truck brake controller thanks you. Good on you getting everything up to snuff - such a better feeling!
Yep, I feel pretty good about replacing everything and knowing that it's acually road-worthy now. Still need to load the Olds in it to make sure there's no clearence issues getting it up the ramp.
Finally had a chance to load up the car. It's tight and makes your butt pucker a little gettting it in there, but it fits. I'm going to install a couple of 2" x12" boards on the floor to raise the car up a bit. That should be enough to clear the side door jamb and let the doort open wider.
Nice fit. A mirror and tire track paint lines may help the butt pucker. Also, putting boards just where you want the wheels finally would help you know to stop, even with a curb on the front two as well.
