Work ongoing
Old Mar 16, 2025 | 07:42 AM
Thebaron's Avatar
Work ongoing
Been a busy few months with work and the poor Oldsmobile has been put on the back burner a bit as no doubt many of us on here are in the same boat. Managed to source both the exhaust manifolds and the complete exhaust system for the twin pipe conversion from a recommendation on the forum by a member. I am still yet to fit them as I recovering from the postage costs from the USA to here in the UK, 80kg in weight which wasn't cheap plus import duty here. Also sourced an Aluminium Radiator in the States and shipped that over which I have had time to fit, just need a NEW Brake Master cylinder now and Alternator which are on their way from Rockauto. New rear Air Jackers shockers and also New front standard ones fitted, managed to get to a local meet last week and she did turn a few heads.
Old Mar 16, 2025 | 09:35 AM
Sugar Bear's Avatar
Nice looking ride!
The fuel line pressure side from the pump to the carb was steel with tubing nuts from the factory. Rubber was used on the suction side of the pump between the tank and the fuel pump.
The risk to using rubber hose and an inline plastic filter on the pressure side is a leak would pump gasoline on the hot engine possibly creating a fire.
Old Mar 16, 2025 | 11:48 AM
Nice looking ride!
Nice car. Kudos. Agree w/ Jeff (above). Best to place that style fuel filter on suction side prior to the fuel pump for reasons noted.
Old Mar 16, 2025 | 02:26 PM
Nice looking ride!
While I agree the factory setup was a steel line. It's been done that way for decades in the hotrodding community. Chances of that type of filter leaking are nil. You're looking at less that 6#'s of fuel pressure.
Old Mar 16, 2025 | 02:59 PM
Eric - I believe your points are valid, as well.
Old Mar 17, 2025 | 12:14 AM
GCH's Avatar
GCH
Very nice car wow what a large license plate on the bike
May 11, 2022 07:15 AM
grannys442
Mar 19, 2022 07:37 AM
tkcutlass
Mar 18, 2022 03:27 AM
J1978
Jun 18, 2021 04:38 PM
Hairy Olds
Jan 4, 2020 07:26 AM
