Thoughts
Old Nov 30, 2009 | 08:32 AM
james455's Avatar
Thoughts
Here are a few pic's of my cutlass project. I am working on it all the time, and cant wait to get in her and go. This is the motor I was having the clearance issues with the valve covers. I am looking at the 7" Booster. Any thoughts or comments will be appreciated
Old Nov 30, 2009 | 08:45 AM
james455's Avatar
some more..the Valve covers. The motor is in the car, the pics below were from last year, with the exception of the motor pic. 461, Torker, Performer heads, mondello jm25-28 cam, demon carb, $$$
Old Nov 30, 2009 | 09:49 AM
66ninetyeightls's Avatar
Land Yacht Captain
Beautiful!!
Old Nov 30, 2009 | 10:24 AM
stevengerard's Avatar
no idea about the booster but great looking car - luv that blue
Old Nov 30, 2009 | 11:23 AM
citcapp's Avatar
Use at least a 8" dual diaphram you will need to meet the vacuum requirements of the original and the single 7" won't cut it. It looks like the dual 8" will fit. Measure 4" from the centerline of your existing booster that should tell you what will fit
Old Nov 30, 2009 | 12:06 PM
james455's Avatar
I was looking around online for a Dual Diaphram 8" booster, most companies list a "universal" 8" DD Booster, will this one work?
Old Nov 30, 2009 | 01:24 PM
citcapp's Avatar
The booster will work. What you have to fiddle with is the rod adapter to the pedal inside the car. You have to have the same length rod and fitting to your brake pedal. The after market sellers of these boosters also have adapter parts so you have to take some measurements then buy the right adapters.
Old Nov 30, 2009 | 01:46 PM
One suggestion is with that much HP, ditch the drums and get disk brakes.
Old Nov 30, 2009 | 01:51 PM
james455's Avatar
I have a set of '74 nova spindles, I am planning on Disc front setup.
Eddie Hansen
Paint
21
Feb 12, 2009 08:58 AM
Fishcity
Jan 23, 2008 11:41 AM
Fishcity
Jan 21, 2008 11:06 AM
GoldOlds
Jul 24, 2007 07:30 PM
bobem12
Jun 18, 2007 03:17 AM
