Sick Vista project W(ar)-Machine (Large Marge)
I had a BOP SFI bellhousing. I used a 1/2" adapter plate between the Mopar T-56 and bellhousing to accommodate the difference in bolt pattern.
That could be why I had no trouble with trans input shaft length.
I will find out how it does when I attempt to mate them together. I need to clean up the garage and then get my engine hoist back lol
Talked with the machine shop today. Intake is finally done but when they went to install the fuel rails they had red ones, when I wanted black, so tomorrow it will be ready, just in time for the weekend
So apparently the machine shop was not done with the intake til this afternoon. But unfortunately one of his new guys damaged one of the rails. So he had to order a new one and i am picking it up monday before work. I really like how he did the bracket as compared to how it was before. When i get it i will grab some more pics.
Any suggestions on what to do with the intake as it will seemingly have a shiny spot from the old bracket being milled away?
I have now put the wagon up for sale if anyone is interested.
https://classicoldsmobile.com/forums...a-cruiser.html
So i had the timing set setup wrong and since i had to drop the oil pan i figured i might as well upgrade. So i went to studs on valve covers, oil pan, and headers. And as you can see in the pic the harmonic balancer had a questionable setup on it so i went to an ARP bolt as well.
I was not a fan of the aluminum look so i taped it off and painted it the same color as the motor itself. Also foamies work fantasic for blocking off threads and such in case people were wondering
If you noticed i taped off the brackets when i painted the intake. and the reason is this. I decided to add some accents to it by adding the same wrinkle coat that i did on the valve covers.
And then i buttoned it all back together. Just a couple more things to tidy up then it will be ready for install/break in. Sorry for all the post updates but it has been a while and figured it would be better split up.
Pulled the motor over the weekend. and cleaned some of the gunk that was built up over the 47 years. Motor has never been separated from the frame from the looks of it. then painted to protect it. same with the top of the core support.
And for those that know me (especially if you look to see the block I had installed in the 69 Hurst when I owned it) knows I cant do basic things, it needs to have my own touches. In this case the wrinkle coating on small items was not enough. So I went and added some pizzazz by adding some blue detailing. came out great I would have to say
