Radiator
Radiator
Hi;
I'm in the process of rebuilding/re-installing a 455 in my 1969 442. When I went to re-install the radiator, I noticed the lower outlet connection on the radiator is smaller that it should be [the correct lower radiator hose is 1-3/4" connection] My radiator has a 1-9/16 connection...so I'm thinking this is the wrong radiator for the car.
I'm looking to get the right radiator with the 1-3/4 outlet...can someone point me in the right direction? I've looked all over the internet and there seems to be some confusion on the correct radiator for that car/engine combination.
If your looking for something that will function I should have a 3 row radiator that could be rebuilt. If your looking for the correct code application for that year I may not be able to help. What part of the country/world are you in? If in the northern states/provinces a 3 row would probably be fine. If your in the southern states you may want to consider upgrading to a 4 row to have the extra cooling. Here's a thread of radiators I've got for sale.
https://classicoldsmobile.com/forums...-shipping.html
John
John
If you can not find the correct radiator , I have seen people make a bushing out of radiator hose to make up difference in the diameter. Or you could put a 1971 and newer water pump and lower hose on that would be the smaller size. good luck with your project
found this on da web
Or you can use a lower rad hose from a '80 - '84 Regency...they have a smaller outlet and fit the same as a Cutlass...also a rad shop can change the outlet for you...saves you a couple hundred.
Alex72cutty
Apr 21, 2015 10:30 AM
