Push rod length checking kits
If you have one of the original push rods, you could measure that one and that should put you in the ball park for the checker rod. I believe the checkers have a pretty wide range of adjustment.
This one should do just fine for a small block. It falls within its range. You can get them from a lot of sources. Shop around for best price.
http://streetperformanceusa.com/i-89...Fcd_QgoduG4ANw
In the past I've used a moroso checker rod, same.
ggriffin1960
January 31st, 2012 10:20 AM
