Oldsmobile 394 engine rebuild/restoration
Old Sep 21, 2024 | 11:59 AM
8691ecirpac's Avatar
My version of a 394
Old Sep 21, 2024 | 08:20 PM
rocketraider's Avatar
Oldsdruid
I can't see too good for the engine stand. Is that a flex damper or a flywheel hiding up in the bellhousing?
Old Sep 21, 2024 | 10:36 PM
Charlie Jones's Avatar
Phantom Phixer
Its a stock slim-jim flywheel with no damper
Old Sep 22, 2024 | 05:38 AM
Bfg's Avatar
Bfg
Nicely detailed, are you looking for a car to put it in?
Old Sep 29, 2024 | 07:33 AM
Cutman's Avatar
Beautiful job on the resto. I am putting my 394 back together (64 Dynamic 88 Fiesta Wagon). The shop manual says to put a sealer on the head gaskets. Is that correct? Do you have any advice on the prep before I put them on ?
Old Sep 29, 2024 | 03:54 PM
Phantom Phixer
The shop manual was written over 60 years ago.
Head gasket technology was not the same as today.
Most modern gasket makers do not recommend any sealer on their gaskets.
The "sealer" is already incorporated on the surface of the gasket.
Make sure the heads and block surfaces are absolutely clean and flat.
Old Sep 30, 2024 | 06:43 AM
Cutman's Avatar
Thanks Charlie. That was my assumption as the gaskets are steel and not composite. I now understand why you say "I choose to restore an Oldsmobile Not because it's easy But because it is hard" I have 15 classic cars and have never hit so many stumbling blocks, mostly parts availability, having to do mod's with the parts I have, broken bolts etc. first thing I did was buy the factory manual but it is still not very detailed. My skill level is probably 7 of 10, so I appreciate the help. Very excited to get the 394 back together and stab it back between the fender wells.
Old Sep 30, 2024 | 08:41 AM
Cutman's Avatar
Charlie
I emailed Best Gasket with the same question Found this interesting:Hello Vince
Yes we suggest using a copper coat spray on both sides of the gasket.
K&W or Permatex.
Roy Lucero
Best Gasket Inc
562-699-6631
Old Sep 30, 2024 | 09:19 AM
Phantom Phixer
Charlie
K&W or Permatex.
Roy Lucero
Best Gasket Inc
562-699-6631
I looked at the Best Gasket set.
The head gaskets appear un-coated.
I can see why they would recommend copper coat sealer.
I am more familiar with Fel-Pro gaskets.
They are coated with a blue substance which acts as a sealer.
Thus, they are applied dry.
8691ecirpac
Sep 21, 2024 09:59 AM
8691ecirpac
Sep 21, 2023 08:08 AM
75 W-30 H/O
Apr 8, 2023 06:23 AM
FTolliver
Jul 2, 2022 04:24 PM
