my first rebuild
Old Dec 2, 2010 | 07:58 PM
dkraus71cutlass's Avatar
my first rebuild
I have a olds 455 engine that has come out of a 1969 delta 88. I am currently in the process of rebuilding. I put and edlebrock cam (part # 2152 from summit) that has a lift of 0.472int and 0.496exh. and also speed pro high compression pistons 30 over stock (part # L2323 from summit)with comp. cam roller rockers. My ? is a will these 3 combinations be alright for the valve clearence? If not how would i check it.
thanks Dustin
Old Dec 3, 2010 | 07:56 AM
InfoJunkie's Avatar
InfoJunkie
It will be fine for valve clearance http://tech.classicoldsmobile.com/102.shtml this link to the tech section will give you more info.
Old Dec 3, 2010 | 11:55 AM
Thanks man
61HolidayCoupe
Jun 27, 2014 01:45 PM
carlstretch
Mar 2, 2013 05:13 AM
FIRST 442
Apr 5, 2011 04:33 PM
Boldsmobile
Oct 30, 2010 08:19 AM
