My 64 J88
Old Jul 17, 2014 | 12:32 PM
88jetstar's Avatar
My 64 J88
So here are some pictures and progress, if any that I am making on the car,
When I was 17
2009
Last month or so
and the stuff I am into now, pulled pretty much all the dash and have gone through and sand blasted and painted the gauge cluster, and everything involved with the heater core and vent box, all this because I was chasing a bad resistance wire for the Delcotron. Now the car actually charges its own battery! I am finishing up with the paint tomorrow and hope to get it back together soon. I have also had a few little surprises pop up
my 1/4 panel came apart while waxing
and my power steering hoses came apart
IMG_20140629_145223828_zpspjbxy3ej.jpg.
So I have solutions for most issues but i still need 1/4 panels lol. I figure I would update this post as I go with the old girl. I have a huge transmission leak and transmission cooler leak, I was thinking of just buying a $800 Jegs TH350 and an external cooler and be done with the junkway 2.
Old Jul 17, 2014 | 12:43 PM
88jetstar's Avatar
work on the HVAC components
Old Jul 17, 2014 | 04:51 PM
Oldskeeper's Avatar
I know a guy up here in Ontario who has both sides in NOS quarter panels for sale, if you are interested in them I could find out how much.I think they will be expensive.
I bought the trunk drops and half way up the quarter and part of the trunk floor for both sides of one of my 63 98s and chopped them up to suit what I needed rather than replacing the quarter panel and I have NOS quarters for this convertible.
Old Jul 18, 2014 | 11:08 AM
Don R.'s Avatar
Nice looking car, I love the side pipes.
Old Jul 18, 2014 | 02:14 PM
88jetstar's Avatar
I am definitely interested in 1/4 panels that are not full of rust and bondo
Old Jul 18, 2014 | 02:17 PM
88jetstar's Avatar
Thanks, the side pipes aren't good for my health with the way its running lol
Old Jul 20, 2014 | 08:14 PM
auto doug's Avatar
Doug - Roller Hoop dude
quater panels
Hi i see your rust issues with your qrts! I just bought a parts car that has pretty decent quarters and of course you will need the outer wheel houses as well! email me I can send some pictures info@rollerhoop.com later, Doug
Old Jul 24, 2014 | 11:00 AM
88jetstar's Avatar
I am debating between rebuilding the 330 or getting a 455. I am not too aware about what is out there for either. What are people's opinions?
Old Aug 15, 2014 | 12:51 PM
88jetstar's Avatar
Small progress, the heater core and vent controls work great, just need some hose for the vents and all will be good, the pics of the paint on the firewall do not do it justice the pics make it look a lot worse than it is. The wires under the dash are still getting cleaned up.
Old Aug 15, 2014 | 12:53 PM
88jetstar's Avatar
On more
Old Dec 3, 2014 | 11:02 AM
88jetstar's Avatar
I started on the front suspension doing the ball joints, then realized i needed everything, so i got new springs, tie rods, a arm bushings, the shocks i have only have a few miles on them so they can stay. I have three questions
1. Are the inner tie rods the same as the tie rod ends? I cant seem to find anything listed for inner tie rod or pitman rod.
2. Do 1964 cutlass spindles fit on the jetstar88? Im asking because i need to redo all the brakes and would like to install disc brakes if i can.
3. Does anyone know where i can get the part that the battery tray sits on or if its the same as an impala?
Old Dec 3, 2014 | 06:06 PM
Eddie Hansen's Avatar
No nothing about the jetstar questions you have sorry just wanted to say thecar is ascool as h3ll... two greasy thumbs up . Looking forward to your build
Old Dec 3, 2014 | 07:05 PM
Charlie Jones's Avatar
Phantom Phixer
1. Inner tie rod ends are not the same as outer . They do turn up on E-Bay.
When shopping for steering linkage , be aware that there were two types used in production . Thompson and Saginaw . To determine which type you have measure the smallest part of the taper on the stud at the pitman arm end of the center link . Thompson will measure .556 in and Saginaw will measure .587 in.
2. 1964 Jetstar 88 spindles are all by themselves. Nothing else fits
The good news is that there is a company called Scarebird that makes disc brake setups .
https://scarebird.com/index.php?rout...tegory&path=62
3. The battery tray is not the same as an Impala. It is common only to 63 and 64 full size Oldsmobiles. A sheetmetal shop that does heating and A/C might be able to bend one up for you.
Old Dec 3, 2014 | 08:13 PM
88jetstar's Avatar
Thank your for the scarebird site. I since everything in my car needs to be replaced i was thinking of using this with 64 cutlass spindles
http://www.summitracing.com/parts/su...ss?prefilter=1
The issue i learned from scarebird is they say for 15 in wheels and my rims are 14 in, so i will need to contact them
Old Dec 3, 2014 | 08:28 PM
TripDeuces's Avatar
Nice car 88jetstar, love it! I just love old big cruisers.
Old Dec 3, 2014 | 08:30 PM
Phantom Phixer
I don't think the Cutlass spindles will work on your Jetstar.
Old Dec 3, 2014 | 09:02 PM
88jetstar's Avatar
With the brackets from the scarebird the calipers and stuff in the summit set should work right?
Old Dec 3, 2014 | 10:08 PM
Phantom Phixer
I really doubt it. Best to speak with Scarebird first.
Old Dec 4, 2014 | 09:44 AM
Don R.'s Avatar
Scarebird's kit is for 61 to 64 and 66-70 full size cars, I think the suspension on your car is a one-year-only hybrid. There are other experts on here who know all the details, but I would be very careful buying any kit unless you are sure it will fit. You may be better off just rebuilding the stock brakes.
jetstar88mike
Brakes/Hydraulic Systems
Aug 3, 2015 09:27 AM
88jetstar
Jun 2, 2014 10:36 AM
88jetstar
Apr 22, 2014 01:43 PM
rennoc442
Aug 30, 2013 09:23 AM
aliensatemybuick
Sep 23, 2010 01:05 PM
