fresh built 455 w/valve tick ??????
![Question](https://classicoldsmobile.com/forums/images/icons/icon5.gif)
Hi, still kinda new at this bear with me, MY distributor bottomed out and the cam gear wore my bronze distributor gear out, oil was filled with metal, i changed the oil and filter and fixed the dizzy problem,when this happened #3 intake vavle started ticking!!!!
????? can some of those bronze gear particals stop up my lifter and keep it fron pumping up, I pulled the vavle cover and thats the only one with a problem, no stuck valves or anything like that.......if so do i have to pull the intake and replace that lifter,
only 10 miles on engine can I reuse intake gasket?
(69 olds 455, 40 over, comp 280h hydraulic flat tappet cam, big valve C heads)
I hate to be the bearer of bad news but the lifter will have to come out and yes the intake has to come off.I personally would not try to reuse the intake gskt-just asking for more trouble later on,even if a good copper coat is used.what really concerns me is if the metal was getting past the filter enough to cause a lifter failure,then has to be damage to the bearings also-rods,mains,cam.the filter should have kept the bad metal out and hopefully you just have a bad lifter that broke a spring or gummed up pushrod etc.have you pulled the pushrod to see if clear?do you have aftermarket adjustable rockers or the factory aluminum towers that take care of intake and exhaust and are non adjustable,and if the factory pivots-were they new and if not check the underside for wear.need more info.let me know and can probably send you in right direction.
BTW-when you changed the filter,did you notice if the filter bypass was still in place?
Thanks, meoff, I do have the stock rocker setup, as I think about it when I pulled the valve cover there was no metal particals on top end of motor and the push rods were clear,I changed the push rod and rocker arm as a precaution and to see if it it would help, still just little loose motion there,fired it up still a little tick plenty of oil flow there, not sure what the oil bypass is and where its located? Thanks for any help you offer..........trab
![Wink](https://classicoldsmobile.com/forums/images/smilies/wink.gif)
December 10th, 2011 07:49 AM
monzaz
September 5th, 2011 10:45 AM
