Floor replacing
Old Jan 22, 2014 | 04:40 PM
krazee442man's Avatar
Floor replacing
I hope this is not a stupid question in some eyes. I am curious, if I have a donor car with a GOOD floor, is it worth the time cutting it out as a replacement or do I go with a NEW floor? The original is a 4 speed floor and so is the donor.
Old Jan 22, 2014 | 04:45 PM
Yes it's worth it. OEM parts are better than repops and the metal will be thicker gauge than repops too.
Old Jan 22, 2014 | 04:55 PM
Thank-you. I was hoping that was going to be the right answer !
Old Jan 22, 2014 | 04:58 PM
Why wouldn't you?
Old Jan 22, 2014 | 05:01 PM
Since I'm asking, can a 68 400 with "C" heads be fitted with a 68 W-30 cam without trouble or would I need to have the valves done ?
Old Jan 22, 2014 | 05:02 PM
Once you have all the donor parts off that donor car, take a good look at the rest of the sheet metal, trim, driveline, interior and frame. If it's solid you have a great parts car that folks with 68/69 would likely be looking for. The replacement market for 68/69 sheet metal still isn't as good as the 70-72 yet.
Old Jan 22, 2014 | 05:04 PM
Have not tackled a restore before. Just wanting to do it right.
Old Jan 22, 2014 | 05:42 PM
Octania's Avatar
I took an entire floor from a donor car and put it into a '69 Cutlass that was pretty badly rusted. It worked out pretty nicely. Carefully trim to the factory joints, then weld together and seal the seams.
jon1957
Body work
16
Nov 2, 2018 09:10 PM
sinfulsemaj
Body work
Mar 18, 2011 02:06 PM
STRETCH1
Body work
17
Feb 22, 2011 12:34 PM
sinfulsemaj
Body work
Feb 4, 2011 10:22 AM
trackz man
Aug 23, 2010 05:18 PM
