Distributor question
Old May 20, 2010 | 07:20 AM
benji94's Avatar
Steve
Hi...just joined up and STARTING on the restoration of my 72 442 W30.
Many years ago, before I ever knew the car would be worth anything, I put in a Mallory dual point distributor. (Seemed like a good idea at the time.)
I want to restore to original as close as I can. That would mean a stock distributor, part #1112036 (I believe from the research I've done). Probably hard to find, if not impossible, but finding a compatible distributor isn't a problem.
I'm wondering what the consensus is about putting in a stock 'appearing' HEI distributor???
I'm not planning on putting the car into shows for judging or anything like that. Just want it to look original but it seems to me that HEI is the better way to go. I'd appreciate others opinions.
Thanks.
Steve
Old May 20, 2010 | 07:41 AM
Lady72nRob71's Avatar
Welcome, Steve!
It is possible to obtain a stock disty and put in an electronic conversion kit (like the lectric limited or pertronix.)
You would have the stock look with electronic low maintenance innards.
Of course you could also keep the points in the trunk in case the electronics ever died on the road - they are pretty easy to swap out.
Old May 20, 2010 | 08:14 AM
benji94's Avatar
Steve
Ok, thans Rob. That's the way I'm leaning.
Steve
chris83
Aug 18, 2012 01:47 PM
B-Mann
Jun 18, 2009 06:13 AM
Bosco1956
Oct 17, 2008 09:57 PM
Bunser
Sep 7, 2008 10:17 AM
OLD SKL 69
Mar 30, 2007 07:33 PM
