Could use some advice.
Old Mar 2, 2015 | 04:09 AM
malone-ren-con@att.net's Avatar
I have a 72 cutlass that I put a new 12 bolt w27 rear end with disc brakes in. My 14 inch rims will not fit hit caliper. What do you think pf spacers. The new engine has a lot of hp and torque. Also the engine builder used an air gap performer manifold. Am I going to be ok with hood clearance. Drop base air cleaner and frame mounts help?
Old Mar 2, 2015 | 04:19 PM
What are you calling a 'new' 12 bolt W27 rear end? Do you actually have a 1970 W27 aluminum differential you converted to disc brakes?? Why??? That thing is rare as can be and is worth huge $$$ as OEM.
If on the other hand you mean you have an O type rear with a W27 aluminum differential cover, why not just go with 15" wheels?
1BOSS83
Nov 15, 2013 03:59 AM
Jrod
Mar 22, 2013 05:01 AM
Bacchus
Aug 31, 2012 06:45 AM
freebird72
Jul 18, 2009 01:09 PM
J-(Chicago)
Jan 8, 2009 04:28 PM
