Correct way to install the windowmolding clips?
Old Jul 29, 2012 | 12:47 PM
marcel442's Avatar
Hello can someone tell me what the right way and order for assembling the front and rear windowmolding clips?
or is there a installation manual or pictures?
I am restoring a 71 442
thanks and greetings from the netherlands.
Old Jul 29, 2012 | 03:14 PM
ah64pilot's Avatar
The first thing to do is install the clips onto the studs around the window. Once you have installed all of them, you will lay the trim over the clip at the edge of the window and press it down firmly. The trim lip will "clip" in between the clips and the body.
At the corners you will have to put the trim pieces together before clipping them in because they "slide" together. Hope this helps
ATrain1
Non-Olds Engines
Jun 29, 2012 12:58 PM
oldzy
Apr 24, 2010 09:13 PM
344870M
Aug 21, 2009 08:04 AM
Ndn_GivR
Apr 18, 2008 04:15 PM
