Ahoy there 70 cutlass here
Old Feb 24, 2025 | 07:02 PM
ithurtz's Avatar
Picked this guy up 2/21/25 for $8500.Going to be a drive and fix as I go. stock 350 2bbl. As of right now it runs pretty good, brake lines need to be addressed before I feel comfortable on the road. Would like to do power front disks. Kind of thinking look wise period correct with some underlying upgrades. Performance wise unless I become rich nothing more than head/cam/intake/stall/exhaust one day. Will take a few years I am thinking to get to the point of paint. We shall see
Ram squatted a bit but drove 1hr back on the highway like a champ, trans never got above 122 degrees in 20 degree temp.
Old Feb 24, 2025 | 07:05 PM
ithurtz's Avatar
Old Feb 24, 2025 | 07:08 PM
ithurtz's Avatar
Old Feb 24, 2025 | 07:30 PM
70sgeek's Avatar
'72 Cutlass ragtop
When I first got my '72 ragtop it was a well enough running car that I actually drove 100 miles home on a 90* FL summer day WITH working a/c!
So my initial thought was to work with what I had in the short run until a bigger total rebuild plan could be crafted
Basic plan I put in place for my 350 2bbl when I first got it was:
- complete tune up (plugs, wires, cap/rotor, belts, all fluids changed new hoses, t-stat, etc.)
- electronic ignition (originally went with the MSD p/n 8529 for that)
- 4bbl intake/carb swap
- dual exhaust (went with Flowmaster 40's originally)
the extended plan once all the basics were covered would have been water pump and timing chain...
In my case however plans changed when I removed the intake and saw 50 years of crud build-up inside the lifter galley - running or not, I pulled it for a full rebuild at that point.
But the basics I think are still a solid place to start if you don't want to go that far into the motor yet.
Old Feb 24, 2025 | 07:39 PM
ithurtz's Avatar
Fixing flickr and uploading them direct to avoid my posting problems
Old Feb 24, 2025 | 07:45 PM
ithurtz's Avatar
Old Feb 24, 2025 | 07:47 PM
ithurtz's Avatar
I got plugs, belts, oil and filter for this weekend if I can to start. I need to do seals (all of them) and brakes before I dig to far. I would LOVE to pull the valve covers to peak and the rockers but......for now I will pretend its mint? lol
Old Feb 24, 2025 | 10:20 PM
I don't know why you're getting double pics either, I can't edit them out. It must have something to do with the way they are saved on flicker.
Old Feb 25, 2025 | 02:50 PM
ithurtz's Avatar
It is weird, I have used flickr for 11 years now and this place is the only place where it does doubles..
Old Feb 25, 2025 | 07:39 PM
ithurtz's Avatar
Let my son play with it over the weekend
https://rumble.com/v6oh4fi-70-cutlass.html
Old Feb 28, 2025 | 09:30 PM
ithurtz's Avatar
I didnt know when you hit the high beams that all 4 lights are supposed to go on. My highs dont work, plugs have power so I guess both lamps went out.
Next sunday is the plan for tune up, belts and oil change. Got a old sears dwell meter from ebay coming, $25. I will have to research idle timing for when we time it after the dwell.
And I did confirm the steering box does leak, and one of the steering linkages underneath has a missing bushing/bearing so steering has some play. All in due time!
Old Feb 28, 2025 | 10:51 PM
1965CutlassGuy's Avatar
9 thats what I mean 11
Originally Posted by ithurtz
Does anyone know where this bolt or thing piece is so I can reattach the front seat to the bottom?
the driver side looks like that
I believe it is these.
https://www.thepartsplaceinc.com/pro...r-seat-ea/9483
Old Mar 8, 2025 | 07:33 PM
ithurtz's Avatar
Did tune up today, plugs, wires, oil, cap etc. Rockauto send me the wrong alt belt, to small and had to run to napa. Previous spark plugs one I unthreaded by hand, the rest were not even tight. Oil filter that was on there was a sears dual, never heard of it. I ordered points from summit but guess they ran out and I got refunded. Ordered from rockauto, acdelco gold and a condenser, car wouldnt start, no spark. After fussing with it for 30min, put the old one back in, sprayed starter fluid in the carb and after running rough probably because I flooded it fired up.
Hooked up dwell meter, was running at 20, got it to hit 30, adjusted idle and timing, she runs even better now. Took it for a quick run around my brothers block, now I understand the gutless cutlass joke LOL. Speedo dont work, cars front end floats like its on a cloud, which is ok because I want to do control arms etc but I wouldnt dare drive it on the highway. Trans shifts from 1-2, I dont know when its supposed to shift from 2-3 as I doubt I went over 35mph. Ordered door seals, drip rail seals, trunk and a window switch just to get the ball rolling.
But hey its a 1 wheel peel red wire spruced up engine bay right now!
Old Mar 22, 2025 | 02:42 PM
ithurtz's Avatar
I went to my brothers to look at a few things. I deleted the emissions mutli port temp sensor thingy with the 4 vac lines attached to it. Started to remove some drip rail seal and behind the seal by the door was white. This had me thinking.
I went to this place https://datatagdecoder.com/ and typed in what I could see. The TR 942 with the 06B in not 100% its a B but close enough. Apparently the car was born white, with a green painted top? If the 45 is a 45 looking from my picture. If in fact it was born white, there isnt a trace of white anywhere on the car, hood, fenders, behind door panels, trunk etc.
Did vin too
At least the interior is original.
Old Mar 29, 2025 | 08:33 PM
ithurtz's Avatar
Starting prep for next weekends work load. Behind and around original master was little rusty. Went to hf got a 110lb blaster tank, went to tractor supply got the fine coal slag sand. I taped things off and covered the entire bay, fenders, and windows with a cloth painting tarp and melted away the surface rust in minutes. It was awesome. Primed it and 3 coats rustoleum semi gloss. I like doing it so much I took the A pillar cover and blasted and painted that too HA. I have the front brake disk conversion, waiting on steering parts, control arms, shocks, springs, wheels, rubber and brake lines. Think thats all I ordered.....?
Old Apr 5, 2025 | 09:57 PM
ithurtz's Avatar
Old Apr 8, 2025 | 07:11 PM
ithurtz's Avatar
Old Apr 17, 2025 | 07:57 PM
ithurtz's Avatar
Mounted and balanced
Old Apr 19, 2025 | 06:36 PM
ithurtz's Avatar
Car is back on the ground. Car sounds like it needs the carb tuned again, new fuel pump and I took away the emissions port thing by the front of the engine. Replaced vac lines with silicone lines, new trans pan (chrome with a drain plug because why not) and filter. Bled brakes, I still have a slow drip from under neath where the hardline meets the flex for the rear. Maybe I can mess with tomorrow. Gen lights on, running at battery 13 volts, maybe i touched something.
If they made the olds wheels in 15x8 I could have stuck with those oh well
Left 245's, middle 215's, right 295.
Little small querks to figure out but its road "worthy". Front end no longer feels floaty, and my god power brakes with disk fronts are so much better. Tracks straight, feels pretty good for just eye balling it.
Old Apr 20, 2025 | 03:21 PM
ithurtz's Avatar
Looked at car again today, no leaking fluid underneath from brakes, maybe the residual was slowing dripped from before. I reattached the high speed blower relay, 2 pumps of the peddle and she fired up super quick. Runs great now. I dont know if that relay was it (doubt it) or it had a bug in it from when I did the fuel pump. Start up voltage was low/mid 14's so all is well there. Watched it for 30min messing around, would dip high 12's to low 13's and stay for some time but the battery isnt draining so who knows. Lights on would be no lower than 12.7.
Forgot to post a picture of the power booster! I give the right stuff pre formed brake lines a B+. All fittings worked, most of the lines were bent correct minus the fact that they were all to l ong by a few inches. The front driver disk to master wasnt even close in shape so I had to bend that all different ways. The disk conversion was spot on, no problems there.
I found this today, no fuse in it, dont know what it powers. Guess I will worry about it later when curiosity strikes more.
Old May 4, 2025 | 06:32 PM
ithurtz's Avatar
Installed tac today, trunk weather seal and door seals, When it was painted green probably 600 years ago they filled in the underside of the door holes where the seals would go, so I had to redrill them. I will go out on a limb and say this was someones project car decades ago and never got finished and just sold off, then sold off again.
Tac replaced the dummy gauge, I cut out the gauge center so the 3 3/8 gauge had something to fit into. Im stuck with this size now so thats what the other 2 will be, but if I did it again I would go the 4.5" factory size.. Black/white during the day and blue with dark red needle at night. Lights are on in pic.
Wash the car today, more than likely will never see water again until its paint time. Windshield and back glass leak LOL, Oh well hopefully nothing to crazy hiding behind there when the time comes . Upon further inspection of the floors, the passenger side front I can see some fiberglass mesh peaking through, so once cleaned up I will have to patches to do.
Old Jul 6, 2025 | 11:53 AM
ithurtz's Avatar
Ok after having a mishap https://classicoldsmobile.com/forums...4/#post1638236 got it all figured out
Threw on a edelbrock rpm intake (EDL-7111) with quick fuel slayer 750 carb (QFT-SL-750-VS) and a 180 tstat.
Used summit fuel feed line SUM-G3110
holley throttle cable bracket hookup HLY-20-88
vibrant -6 nylon braided fuel line VPE-11956
summit hose end clamps SUM-220906-B
trans-dapt fuel filter TRD-9245
BMR chassis brace BMR-CB410R
front away bar BMR-SB008R
chassis brace was a pain in the *** to install, hated every second.
Chassis brace need rivnuts, couldnt find a 7/16 for my tool so saw a way to use it with a nut and metal plate
Throttle bushing was ***** inline tube ordered new bushing, sleeve and clip. Clip was way to fat to fit the quickfuel, tried using the stock clip but it keeps popping off. Might have to put a snap ring in the little groove to hold the cable and bushing on
Want to mess with timing next weekend and dial it in better after this, then Ill just drive it. Have nothing else planned to do to it this summer.
Old Sep 21, 2025 | 05:38 PM
ithurtz's Avatar
Iv seen people use this google geminii thing for cars thought I would play with it. No I dont know who the dam driver is, it took me out and put some ai fruit loop in their.
Charcoal
by https://www.flickr.com/photos/202313575@N03/, on Flickr
Gold
teal?
orange
navy blue
I then gave it a rear shot and asked to put a spoiler on, did pretty good job. the ai isnt good with hoods though
navy blue with spoiler added
supposed to be viking blue with spoiler added on... this things fun to play with
Old Apr 25, 2026 | 05:19 PM
ithurtz's Avatar
Lady booted me from the house earlier this year after 17 years so things will go slower than I wanted.
Brought the cutlass over yesterday, needed to add 1.5 quarts to the trans to get her moving without high reving. Looking under it today I have like 3 spots of oil dripping so I will have to look at see wtf.
Checked dwell, spot on, adjusted the floats, checked vacuum and added a fuel pressure gauge because I wasnt sure if this pump was putting out more than it should. Cold start it would need to have its throat cleared for 30 seconds before high rpm would take over. Also adjusted the secondary's to delay a bit to reduce bog. Gauge jumps around from 4-8ish so psi is good.
Old Apr 26, 2026 | 05:03 PM
ithurtz's Avatar
Think the trans is taking a ***** reverse slips bad. .
When that time came I wanted to do a 4l80e, but I dont have time to do all that and wait for a driveshaft to be made. Buy things to tinker with, its letting me tinker alright. Maybe look at carb internals too, somethings got to be leaking internally for it to run that rich and need its throat cleared on cold startup.
Old May 2, 2026 | 05:24 PM
ithurtz's Avatar
Messed with timing today trying to mess around. Set it to "12" per oem (I had it at 22ish)and ran worse and almost took my face off with a fire ball shooting up the carb. So I kept cranking the timing up and up while reving and ran better and better great response. Put it at 34, but it didnt like trying to start that high so I dropped it to 30. Could probably drop another 2 degrees but I will leave it there for now. The 53 it is reading is with the advance hooked back up. The part idle bog I have been fighting since day 1 is just about if not gone once warmed up. Drove it around and it was great, just slow as ***** my truck would kick this things ***. I started it a few hours later and as of right now dont have any of that cold start "having to clear its throat" before high rpm kicked in.
Fuel gauge needle is now rock steady and not bouncing around.
Dog doesnt know what to think of the cutlass, thinks it is weird, and doesnt like the noise it makes. Trans still slips in reverse, I dont think there is anything I can adjust, forward gears are strong and normal.
Cosmic Charlie
Jan 7, 2024 08:32 PM
Cosmic Charlie
May 2, 2023 05:55 AM
Falkon
Dec 31, 2022 05:41 PM
droptopron
Sep 11, 2017 07:53 PM
