72 Cutlass Supreme
Old Jul 23, 2009 | 08:00 AM
steve11711's Avatar
72 Cutlass Supreme
This is my 72 Cutlass Supreme. I got it for a thousand bucks a couple of weeks ago. The guy i got it from bought it at a repo auction so i don't have alot of info about the car. To tell you the truth i don't know much about olds in general but i sure do love this car.the guy i bought it from thought it had the stock 350 in it. But upon closer inspection it looks like i've got a 455. As you can see in the pictures the body is in pretty good shape. Just missing some trim and the grille. The interior needs an over haul. The engine runs good enough. It needs to be timed and tuned. I'm hoping i can get some advice on the engine. I don't really know what kind of power i'm getting from it now and i'm hoping a can get close to 600 horses from it. Let me know if i'm crazy or how i can make this possible. Any input or advice is appreciated. Thanks
Old Jul 23, 2009 | 08:04 AM
steve11711's Avatar
looks like i didn't get the pictures right the first time. Lets try that again.
ent72olds's Avatar
Registered Luser
Can't see pics Steve....if it is a 455, it is possible to get 600 out of it with some help and it all depends on your budget! I can see pics now!
Old Jul 23, 2009 | 08:07 AM
steve11711's Avatar
sorry the pics aren't that great. all i had on me was my blackberry. i'll get the digital camera out when i get home and get some better ones. as far as budget i'll do whatever needs to be done. i'm ok if it takes awhile to get it done too.
Old Jul 23, 2009 | 08:54 AM
67 Cutlass's Avatar
From what little I can see from the pics it looks like you got a great deal for $1000!
It looks more like a 69 or 70 going by the tail lights unless that was changed out by the previous owner
Either way, you're in good hands on this site
Old Jul 23, 2009 | 09:08 AM
citcapp's Avatar
Talking Wow!
Great deal, you can get to 600 hp, its all about the $$$$$$$$. All of the running gear has to be modified as well to handle it, and don't forget brakes, the faster it goes the harder it is to stop. Looking foward to more pictures and good luck with your build
Old Jul 23, 2009 | 09:12 AM
steve11711's Avatar
As far as the brakes go i know it's got front disk, rear drum. the rear need to be completely replaced. i think for the time being i'll stay with the drum. but i have looked at the disk conversion kits.
Old Jul 23, 2009 | 09:17 AM
steve11711's Avatar
i never noticed the tail lights being different on the 72's. it does look more like a 70. i'll have to check the vin again.
Old Jul 23, 2009 | 09:19 AM
steve11711's Avatar
k i pulled the vin
3J57K2R140835
i'm pretty sure i ran it and it's a 72. i guess they must have switched out the bumper and tail lights
ran it again. it says its a 72 cutlass supreme. 2 door holiday hardtop. 350 (5.7) v8 4bbl made in arlington texas. serial number 140835.
so they just have switched out the bumper.
Old Jul 27, 2009 | 08:10 PM
Lars's Avatar
the rear bumper is a 70 bumper, the hood is a 71-72 hood. the 71-72 hoods are the same. on the intake does it say performer 455 or 350
and as long as the frame is ok, that's a GREAT deal
Old Jul 28, 2009 | 05:35 AM
Cool car. Welcome to our site. Post any questions you might have and someone will surely know the answer.
Old Jul 28, 2009 | 07:55 AM
steve11711's Avatar
It says performance olds 455.
Old Jul 28, 2009 | 11:56 AM
mcutlass1969's Avatar
Edelbrock Power Pack
Well if you go and purchase the Edelbrock Power Pack combo you will have all the power you will ever need for the street. Then you need to look at upgrading the tranny and rearend. As previously stated it is all about the $$$$
Old Jul 28, 2009 | 03:48 PM
Lars's Avatar
what are the #'s on the shelf infront of the water neck? their cast into the block
396021 F?
the letter on the head
G, H, J, E?
Old Aug 13, 2009 | 03:11 PM
Coltonis's Avatar
If the engine has been swapped out you can check the cast to get some general info as lars said.
If the letter is an F its a 455 from a 68-72 if its an FA then its a 455 from a 72-76.
To get more info though you need to check a flat pad that is cast into the block and then stamped with a serial, it is just below the head on the driver side of the engine towards the front of the engine/car. Its very difficult to locate/see and the faint stamping is usually completely hidden by paint/dirt/rust.
If you do manage to see the serial. I believe the second digit in the serial shows the last digit of the year of the block (ie for 1972 the second digit in the serial will be a 2; or for 1975 the second digit will be a 5) There should also be letter in there too that will tell which plant the engine was made at... good luck
Oldssupreme
Apr 3, 2015 08:36 PM
travisbeamon
Aug 7, 2011 12:51 PM
olds70supreme
Aug 1, 2011 05:22 PM
70_CS
Mar 17, 2009 03:25 AM
72droptop
Jul 27, 2007 07:52 PM
