68 Cutlass Power Window Help
Old May 20, 2018 | 07:17 AM
Xlhowie's Avatar
I had a shop install the wiring for my OEM power windows. Windows didn't work so I decided to remove the motors and re lube them. When I did the big assist spring on the regulator fell off and I cant figure out how to reinstall it. Driver (LH) side on the top of the tab or the bottom???
I cant find a picture or any other help, so here is where all the smart folks are.
Any help will be appreciated.
Thanx, Howie
Old May 20, 2018 | 07:40 AM
lemoldsnut's Avatar
I did this too and think I put them on backwards so now have to help the windows get up all the time. I know I need to disassemble the door panel to check and just have not had the desire to do so. Once the top is down (convertible) for the summer it pretty much stays down and so does the windows. So interested to see who helps on this.
Old May 20, 2018 | 08:31 AM
19684424speedconvertible's Avatar
I have a set in the pole barn,I`ll try to look at them and see if I can get an answer for you.
Old May 20, 2018 | 09:07 AM
Xlhowie's Avatar
Thank you. A picture would be worth a thousand words,,,LOL
Old May 20, 2018 | 09:13 AM
Xlhowie's Avatar
Well, a simple not necessarily easy fix would be to flip them over and reinstall. I am not finding any pics that I can even use. Good luck, Howie
Old May 20, 2018 | 11:18 AM
Front or back window?
Old May 20, 2018 | 11:31 AM
Rear driver side
Front driver side
Old May 20, 2018 | 11:41 AM
Xlhowie's Avatar
Perfect, perfect perfect, thank you very much!! Howie
I'll let you know how it goes.
Old May 20, 2018 | 01:54 PM
Glad I could help .
Old May 20, 2018 | 08:02 PM
Yellowstatue's Avatar
If you are removing the motor from the regulator you must put a bolt through the two sections to keep them from collapsing BEFORE you remove the motor. If there are no obvious holes for the bolt then you must drill them yourself. The first time I tried to remove a power window set-up I almost amputated my poor finger!!
Old May 21, 2018 | 10:59 AM
Xlhowie's Avatar
Too, late, kinda blew up when spring fell out. Its back together now and seems to be working ok. Thanks
Olds luvr
Mar 19, 2015 09:34 AM
Bitburger
Feb 8, 2013 08:24 AM
f-85
Jan 16, 2012 06:10 AM
jugdish
Aug 18, 2011 09:57 AM
hotrodstingray
Jul 7, 2008 04:48 PM
