68 442 motor pics.
1968 442 vert resto-mod
Thanks for the feed back, the motor is installed and the spec's are; 455 + .030
speed-pro L2323f
holley 750 vac sec
big valve"C" heads 76cc
port+polish with some bowl work
harland sharps
high volume fuel pump
performer intake,port matched
Jm-22-25-10, cam kit with springs
msd pro billet, msd6-al, blaster 2.
t-400, shift kit, tci breakaway , 3.70 richmond, eaton posi,moser axels
flowteck hedders
459.02 hp@5000 rpm, 531.47 ft,lbs tq@3750rpm
this was measured at the crank .
speed-pro L2323f
holley 750 vac sec
harland sharps
flowteck hedders
Thanks, I used the stock valve covers. I believe that my engine builder had to grind out one of the baffles that is located on the under side of the valve covers.
Was wondering if you could make that much hp/tq using a 750 vac secondary holley,and a performer.Looks good....Good luck with it.My build is pretty close to yours,and I was thinking about 450hp.500+tq. I might be close.
Thanks, if this car does run mid 12s I'd be happy but with the springs being so stiff it kills the tires off the line. As far as price goes for this build, motor was about 9k, the whole build totalled about 42k. This doesnt include the time that I spent running around or the hours spent in the garage cleaning/painting parts. The power and torque figures were given to me by the engine builder, he also said that he made a couple of runs with an HP series carb and found little or no change in power or torque.
19camaro95
December 3rd, 2010 01:50 PM
