394 "Rocket" engine build
Old Jun 23, 2020 | 05:23 PM
  #81
Charlie Jones's Avatar
Phantom Phixer
Originally Posted by 64Rocket
well it is almost 2 years. I wonder what has gone on. Must be running or close to running. I hope all is well with the project.
Gene
I'm getting close to running it .I'm almost finished with the chassis , the exhaust is installed , the A/C compressor and alternator and fan belts are on .
Next project will to be to hang the radiator in front of it , get a battery and a gas can , and run it .
I'll probably run it for 1/2 hour between 1500 and 3500 RPM to break it in .
I even have a Jeg's thermometer installed temporarily in the port for the " Idiot " light .
Old Jun 26, 2020 | 09:50 AM
  #82
Don R.'s Avatar
Looking good Charlie. Was your car built with factory A/C?
Old Jun 26, 2020 | 12:43 PM
  #83
TripDeuces's Avatar
Hot day in FL, hehe
Old Jun 26, 2020 | 04:44 PM
  #84
Phantom Phixer
Yes it was , sold new in Alamogordo , NM .
Old Jun 26, 2020 | 04:48 PM
  #85
Phantom Phixer
Originally Posted by TripDeuces
Hot day in FL, hehe
And that temp was in the shade !
Old Sep 12, 2020 | 11:36 PM
  #86
Phantom Phixer
It runs !
The good news is I got this beast running for the first time since I assembled it in 2018 .
The bad news is that the fuel line ( from pump to carb ) was leaking gasoline .
Here's a video ;
Old Sep 13, 2020 | 04:23 AM
  #87
Inline's Avatar
Nice!
Congratulations- must be a great feeling. Gives a bit more will to make the car complete again, aint it?
Old Sep 13, 2020 | 09:41 AM
  #88
Phantom Phixer
Originally Posted by Inline
Nice!
Thanks , I can't wait to drive this car .
You're right , this gives me even more motivation to " git 'er done " ,
Old Sep 18, 2020 | 08:52 PM
  #89
Super88 holiday's Avatar
Windage tray
Hello. I checked out your build of 394. Great work. I just bought a 1963 Oldsmobile super88 holiday with a 394 That was rebuilt but who ever built it Never compensated for the oil pump relief sticking out and I was hearing a knocking noise from the engine. It was the crank hitting the windage tray. My question is even after you made a relief mark in it did it not hit the crank with that minimal clearance ?.
Old Nov 19, 2020 | 02:41 PM
  #90
394 Guy's Avatar
20lbs to start it moving or keep it moving?
My 394 in the same state of rebuild takes 32 foot pounds to get it moving. All the components are lubricated.
Old Nov 19, 2020 | 05:02 PM
  #91
Phantom Phixer
I actually bent the windage tray to clear the relief valve .
Looking back on it , I should have cut a notch in the windage tray to clear the oil pump relief valve .
Old Nov 19, 2020 | 05:06 PM
  #92
Phantom Phixer
If you have checked the ring end gap , the piston to wall clearance , and the bearing clearances you should be OK .
Old Dec 14, 2020 | 02:52 PM
  #93
59oldsthunder!'s Avatar
So you were the guy doin this 394 I remember I could view it but I wasnt a member yet! Was havin trouble with the email to confirm me,anyway that looks badness how is it runnin?
Old Dec 15, 2020 | 06:52 PM
  #94
Schurkey's Avatar
Fun thread. My only 394 experience was with a '64 full-size that two friends of mine bought to "flip" way back when we were all in high-school.
Did you ever get dyno numbers?
Old Dec 15, 2020 | 07:01 PM
  #95
Phantom Phixer
I got the fuel leak fixed .
I ran the engine for a total of 45 minutes or so . At least enough to break in the cam .
No, I didn't dyno it . Maybe a chassis dyno after the car is assembled .
Old Dec 17, 2020 | 09:19 AM
  #96
pherbicide's Avatar
Wonderful thread! Great information, pictures and journey. Excited to see the build continue!
Old Jun 18, 2021 | 09:42 AM
  #97
57JoeFoMoPar's Avatar
This is one of the best First Gen Olds build thread resources on the internet. Great work.
Old Jun 18, 2021 | 01:26 PM
  #98
OA5599's Avatar
Originally Posted by tunafish
All done runs great
Incredible.
I wish I could just get your build as a crate motor.
Old Jun 18, 2021 | 03:26 PM
  #99
therobski's Avatar
It is indeed! Your only original once...
Old Jun 18, 2021 | 04:35 PM
  #100
Phantom Phixer
Thank you very much .
When I started this thread there weren't any 394 build threads . At least on this websight .
The 394 and earlier engines have some unique engineering , as opposed to a Chevy or even a '65 and up Olds ,
It was those nuances , that I wanted to get across in this build thread .
Old Jun 18, 2021 | 06:37 PM
  #101
I totally agree. It's an engine, it's not brain surgery. People treat these first gen engines like there's some sort of black magic to them. In reality, they're caveman simple with a bit of specific issues to be not he lookout for. Your thread addresses those nuances perfectly.
I've got 6 first gen engines including the 324 humming away in '56 Holiday 98. Looking forward to building one for one of my other projects and I'll surely use your thread as a valuable resource.
I have a 1960 Motor Manual that has all of the torque specs, technical data, bearing clearances, etc. I'll scan them and include them
Old Jun 19, 2021 | 07:43 AM
  #102
Thats good to hear just love that set up olds power all way!👍👍im workin my 394 hopin soon be roarin!good work sir!
Old Jun 19, 2021 | 08:05 AM
  #103
Phantom Phixer
Last night I was surfing the net . Pretending I had just won the lottery , and was shopping for cars .
I saw a good looking '62 Starfire coupe . It was maroon , with a good original red interior .
When I got to the underhood shot , I almost puked .
There was a small block Chevy , in place of the 394 . UGH !
Old Jun 22, 2021 | 04:06 PM
  #104
Ya that be bad to have 350 chevy in 394 place big mistake I think,another thing bout 394's an all 1st gen big block olds is the timing order is different than later v8 olds that was some awesome engineering I should of became a engine maker!
Old Jun 22, 2021 | 05:11 PM
  #105
Phantom Phixer
A 394 Olds ;
Was the winner of the first Daytona 500 .
Has an " air gap " intake manifold , from the factory .
A forged steel crank , from the factory .
Full floating piston pins , from the factory .
" Beehive " valve springs , from the factory .
A " four and seven swap " firing order ( 18736542 ) , from the factory .
Old Jun 23, 2021 | 01:15 PM
  #106
Thats cool never knew a 394 won daytona! What is air gap intake mean?
Old Jun 23, 2021 | 05:21 PM
  #107
Phantom Phixer
Lee Petty ( Richard's dad ) won the first 500 in a 1959 Olds Super 88 .
An " air gap " intake is one where the intake manifold is completely separated from the valley cover .
Supposed to make for a cooler intake mixture .
Old Jul 3, 2021 | 01:03 PM
  #108
Found more info bout 59 394 winning 1st daytona!
very cool facts!
Old Jul 3, 2021 | 04:14 PM
  #109
Bfg's Avatar
Bfg
The first car I ever drove was my Grandpa’s 63 Dynamic 88 4 dr. Holiday Sedan with the 394, I was probably only 13 at the time. I would get those tires spinning pretty good on those gravel roads!
Old Jul 3, 2021 | 08:52 PM
  #110
Phantom Phixer
The 1959 Daytona 500 finish ;
The '59 Chevy #48 was a lap down .
Lee Petty #42 was just that far ahead of Johnny Beauchamp #73 in a Ford Thunderbird after racing 500 miles .
The flagman awarded the checkers to Johnny Beauchamp , but Petty protested .
Bill France and his NASCAR crew poured over news photos and photos provided by fans for 3 days .
They finally determined Lee Petty and the '59 Oldsmobile the official winners .
Look at the crowd , right up against the fence .
Old Jul 4, 2021 | 04:27 PM
  #111
Theres a online place I was lookin for olds parts,the guy said on phone they sold any parts for olds motors except 394! Said 394 was not never a performance engine! Need show him this! Since I been on here I found some good places to get parts!
Old Jul 4, 2021 | 05:59 PM
  #112
Phantom Phixer
Show " that guy " these photos too .
From the Don Garlits Museum of Drag Racing in Wildwood , FL ;
Old Jul 5, 2021 | 01:35 PM
  #113
Wow nice a blown old!👍 isnt that where j2 came from? Olds had a 371 b4 394? Right thats some bad engines! That one charlie buillt is bad! I gathering parts for mu 394 oh ya!
Old Jul 5, 2021 | 05:47 PM
  #114
Phantom Phixer
If you ever come to Florida , the Don Garlits Museum is a "must see " for any gearhead .
Two or three hundred cars on display . Sometimes Don himself is there .
On I-75 a few miles south of Ocala .
Old Jul 5, 2021 | 10:27 PM
  #115
Phantom Phixer
1949 thru 1953 was 303 cu in .
1954 thru 1956 was 324 cu in .
1957 and 1958 was 371 cu in
1959 and 1960 also had 371 two barrels .
1959 and 1960 four barrels and all 1961 thru 1964 engines were 394's
The J-2 option was introduced in 1957 and consisted of a special manifold with three two barrel carbs .
It was discontinued after the 1958 model year .
There were two blown Olds motors there . One with a 6-71 blower and the other ( Bill Mullins ) with an 8v-71 blower .
Old Jul 7, 2021 | 02:39 PM
  #116
Well got 1 manifold done 1 more go high heat paint silver oh ya, they dont make em that way anymore too bad!
Old Jul 7, 2022 | 03:13 PM
  #117
59 394 olds
Hey olds fans,well just got all my parts to finish building my 394I just got mains from fleabay it looks like hole in bearings was overdrilled will that mess up journal? Thats right where crank rides would you all use them? Heres some picss
Old Jul 7, 2022 | 06:21 PM
  #118
Phantom Phixer
They look OK to me.
Make sure the holes line up with the oil passages in the block when you install them.
Old Jul 7, 2022 | 07:37 PM
  #119
64Rocket's Avatar
Bearings
The hole look ok. Like said, make sure the line up in the main saddle.
The pic’s make the bearing surface real ruff.
I hope it is only in the camera.
I took a 394, boared and stroke to 431 cid. Use #23 heads, dual quad intake. Sanderson made some headers. That thing would scream. Then we put a blower on it, couldn’t keep the big Mikey Thompson tires on the ground.
Gene
Old Jul 8, 2022 | 03:01 PM
  #120
Ya sounds good guys,I guess theres a coating they put on them, after a while it starts wearing off which makes em look rough gonna go over them with scothbrite pad!I will post how progress is goin! Callin camcraft next week for correct cam!
