1980 eldorado swap
Old Aug 11, 2009 | 01:40 PM
nitinnelapudi's Avatar
1980 eldorado swap
I have a 1980 eldorado with a 368 big block in it.
I want to swap it for a olds 350.
I found a 1979 eldorado with a diesel olds 350 that has been converted into a gas engine. well over 150,000 miles on it.
What should be the correct process to swap engines?
Should I remove the engine and then rebuild 350 engine and then replace into the 1980 car?
Can i use existing transmission in the 1980 or should i swap that out with the donor engine?
Thanks for your help.
1969camaross350
Oct 1, 2025 03:22 PM
nitinnelapudi
Apr 7, 2024 04:48 AM
DeadBang1968
Jan 19, 2011 06:35 AM
jaunty75
Dec 16, 2010 05:32 PM
veltboy618
Brakes/Hydraulic Systems
Nov 2, 2010 09:51 AM
