1968 cutlass swapping 350 to a 455
Old Apr 13, 2023 | 02:12 AM
blp's Avatar
blp
I have a 455 that ready to install in my 1968 Cutlass convertible.
The dyno readings are 380 hp and 525 pounds of torque.
I have a freshly rebuilt TH400 transmission also.
Disc front brakes / drum brakes rear.
Besides the torque converter and a larger diameter exhaust system I'm replacing.......
What should I be aware of
radiator......etc
thanks as always... everyone here is so generous with knowledge and I appreciate it!!
Old Apr 13, 2023 | 06:06 AM
I'm in the camp of if it ain't broke don't fix it. Do your swap and see what your temps are running, then make an educated decision on a radiator.
Old Apr 13, 2023 | 06:52 AM
blp's Avatar
blp
I'll pitch my tent and see what it brings.... much thanks sir
Old Apr 13, 2023 | 08:32 AM
JohnnyBs68S's Avatar
You probably already know these things:
- The cross member needs to move back to the TH400 location (depending on prior transmission)
- E-brake cables need reconfiguration for the new crossmember location (use PNs for 442 AT)
- Driveshaft may be shorter (depending on prior transmission)
- Kickdown switch for TH400 (depending on prior transmission)
- PRNDL shifter replaced w/ PRNDSL (depending on prior transmission)
Old Apr 13, 2023 | 02:16 PM
blp's Avatar
blp
Old Apr 13, 2023 | 02:17 PM
blp's Avatar
blp
thank you thank you
I'll take these notes to the guys installing
very much appreciated !!!!
Old Apr 14, 2023 | 05:15 AM
olds 307 and 403's Avatar
Out of Line, Everytime😉
How many core radiator does it currently have? What does it have for a fan and shroud? If it is a rebuilt motor, why risk an inadequate cooling system?
joeype
Mar 18, 2023 08:03 AM
Bullwinkle
Sep 27, 2022 05:46 AM
1968Cutlassfallbrook
Feb 15, 2022 06:31 AM
tcarroll
Sep 1, 2012 02:04 PM
88hurstolds
Aug 6, 2012 09:08 PM
