1966 Toronado Frame Off
Old Jan 6, 2013 | 01:49 PM
  #41
OLD SKL 69's Avatar
GM Enthusiast
Another source for parts/info you might want to look into would be the Toronado owners association. Their website is www.toronado.org. May be able to find the metal dash you're looking for instead of fabricating a new one.
Old Jan 8, 2013 | 06:59 AM
  #42
chazzer's Avatar
Hey Harald,
That is quite the project you have going on.
I’m knee deep in my 68 Toro as well.
http://www.toronado.org/forum/viewtopic.php?f=1&t=593
Although I didn’t take the body completely off the frame. I did jack it off the frame to change the rear mounts.
I reviewed the previous owners page and looks like he thought he was doing a good job on that old 66.
I am in the Autobody industry and have been for 30 years. I have seen a lot of crazy piece-meal patch work in that time. Even cars that look absolutely perfect can have some hidden secrets.
Best of luck!
Old Jan 9, 2013 | 10:03 AM
  #43
61reoldsman's Avatar
Hey Chazzer nice work your doing hope you get it
ready for 2013 , love to have a look at it , Cool car !
Old Jan 11, 2013 | 04:59 AM
  #44
chazzer's Avatar
Thanks 61, It's very doubtful that the Toro will be ready this year.
Old Jan 12, 2013 | 11:19 AM
  #45
harascho's Avatar
paint stripping and surprises
I started stripping the paint and filler in the traditional way, a heat gun and some scrapers. I had a very thick layer of filler and found an interesting repair on the right rear quarter.
Next thing will be sandblasting inside and out.
Harald
Old Jan 12, 2013 | 11:35 AM
  #46
oldsguybry's Avatar
NOVICE car nut
Wow , this is great work ! It seems you have got a lot accomplished !
Old Jan 12, 2013 | 11:44 AM
  #47
harascho's Avatar
I do my very best ...
but I still have some highlights to be addressed... and I have no glue how to get by..
The very next step before sandblasting all is a kind of rotisserie. A different one, I will mount the body to the ceilling... I just fabricated the front and rear mounts for the body.
Harald
Old Jan 13, 2013 | 09:58 AM
  #48
oldsguybry's Avatar
NOVICE car nut
Harald
Search some of the major restoration threads on this site . Most of these guys make their own rotisserie .
Old Jan 19, 2013 | 10:55 AM
  #49
harascho's Avatar
simple rotisserie
I found some time the past week to built a rotisserie and prepare the body for sandblasting. I am using a handwinch to turn the body over and / or fix it in position. The only thing left is enclosing the area with plastic foil to keep the dust in on corner of the shop.
Harald
Old Feb 10, 2013 | 07:56 PM
  #50
Charlie Jones's Avatar
Phantom Phixer
Fabulous job on this car so far! I have never seen a rotisserie suspended from the ceiling. Very inventive idea.
I guess I don't have to tell you that "California car" does not always mean "rust free car". California has some mountainous areas in the north part where they use a lot of road salt.
Stay with it though, your fabrication skills are better than most of us. I am sure you will have a very nice car when you are through.
Old Feb 10, 2013 | 10:11 PM
  #51
harascho's Avatar
thanks Charly for the encouraging words. That helps a lot.
I couldn't work on the car the past two weeks, I caught a bad cold and the part of the shop where the Car is for blasting is not heated
Harald
Old Aug 25, 2013 | 09:18 AM
  #52
harascho's Avatar
more work done
Hi folks,
its been a while and work on the Toronade was kind of slow but I was able to get some things done. Most of the sheetmetal is repaired, even the big problem of the front windshield frame / dashboard is done.
I was able to paint the interioir and the underside with 2 layers of KBS coatings . As I try to avoid bondo I had an old guy show me how to use lead instead. I still need more practice but it works. Only drawback of the lead so far it needs a lot of time and patience to get it in shape..
See the pics..
Harald
Old Aug 25, 2013 | 09:21 AM
  #53
oldstata's Avatar
Justin
Yes lead work is becoming a lost art. great job!
  #54
harascho's Avatar
seats prepared
I also addressed the seats, had new covers made and sandblasted the seat bases and sprayed them with 2 coats of black..
Old Aug 25, 2013 | 09:43 AM
  #55
harascho's Avatar
dashboard
the front windshield frame and the dashboard were still my biggest concerns... but if you take your time, then think about a solution and try to do it right the first time, everything can be done.
Look at the before and after....
Old Aug 25, 2013 | 09:45 AM
  #56
Don R.'s Avatar
Hi folks,
Harald
The good part about lead is that once you are done it is there forever! Looking good.
  #57
harascho's Avatar
lead instead of bondo
and finally some lead work
Old Aug 25, 2013 | 09:58 AM
  #58
harascho's Avatar
another time consuming piece
that was the rear glass frame... I fabricated a new top part out of a single piece of sheetmetall... hours were not counted....
again I like the before and after pics..
Old Aug 30, 2013 | 08:57 PM
  #59
cadillac kevin's Avatar
great thread! I found it very informative.
Old Nov 13, 2013 | 09:54 PM
  #60
harascho's Avatar
Toronado update
just a brief update:
Toronado is in paint preparation. After the lead work a buddy of mine is working on perfect straight sheetmetal. We hope to get it painted by the end of this year.
In the meantime I started on the engine. I had luck and it really was "overhauled": new timing chain, new valve train, new main bearings, a bored / honed block with new pistons... So my work will be only cosmetical...
Harald
Old Nov 14, 2013 | 08:26 AM
  #61
dc2x4drvr's Avatar
Awesome job, nice craftsmanship!
Old Nov 16, 2013 | 10:46 PM
  #62
harascho's Avatar
motor parts
as I still have the motor open...
It was overhauled thats for sure but I didn't check the rear main seal. I hope the builder put in a new two piece rear main seal type. ( I remember the big block ford types fit..)
Elsewhee I read not every rope type seal could be converted to a two piece rubber part...
If anyone knows more pls help me out..
Harald
Old Nov 17, 2013 | 12:28 AM
  #63
Killian_Mörder's Avatar
By the way is there a second source for the big front wheel bearings except fusick? 229USD is not a bargain...
I do business with these people. Unlike many outlets in my area, this one takes seriously customers who aren't out to buy 100 items at a time. Their prices are also reasonable and they stock genuine SKF bearings. Simply, send them specifications for your requirement. If they have something close enough, any difference can get compensated through pressing in bushings to close the space between inch and metric measurements:
http://www.schleer.de/
...Sie benötigen CAD Daten für Ihre Konstruktion ? Bitte klicken Sie auf das Logo von NTN-SNR...
http://www.schleer.de/produkte/mecha...ung/index.html
...Auch können wir kurzfristige Mechanische Berarbeitung wie Axialgewinde, Radialgewinde, abgesetzte Zapfen oder Gewindezapfen und vieles mehr realisieren.
Senden Sie uns bitte Ihre Zeichnung !...
...it really was "overhauled": new timing chain, new valve train, new main bearings, a bored / honed block with new pistons...
I would recommend confirming that Toronado specification replacement parts were installed, before assembling the engine and installing it, since you didn't do the work yourself. The entire valvetrain is exclusive for Toronado only, for example. The valve timing and lobe lifts can be measured, as well as the compression, to verify that you have the correct pistons and camshaft. A lazy shop will just install whatever they have laying around which will cost you horsepower
Old Jan 1, 2014 | 04:37 AM
  #64
harascho's Avatar
harmonic balancer
As I am visiting the machine shop tomorrow.... does anyone have an exact dimension of the harmonic balancer's diameter where the front oil seal rides on? It' a '66 425 V8 out of my Toronado. I had to buy an aftermarket balancer 'cause mine fell apart... I have to work a little on the counterweight to make it fit..and I realized the outer diameter is 51,38mm and the oil seal sits a little too tight for my personal taste.. data from the national oil seal say it is for a 2" shaft and that's only 50,8mm. So before I modify mine I like to confirm with another original balancer...to be on the safe side. My original one is not for measuring.. the surface is shot... I modified it for a different oil seal and had to realize that I cannot find a company to overhaul the rubber part.
Thx a lot... and a happy new year for all of you
Old Jan 1, 2014 | 04:41 AM
  #65
harascho's Avatar
more pics along the way...
paint preparation...... countless hours still went in the already lead straightened metal..
Old Jan 1, 2014 | 05:00 AM
  #66
harascho's Avatar
and some before - after ones..
see some more...
Old Feb 24, 2014 | 12:19 AM
  #67
harascho's Avatar
the long way to paint.....
Here are some pics along the way to the paintshop...
Old Feb 24, 2014 | 06:22 AM
  #68
bluecab's Avatar
Mostly Gristle
Looks great! When do you begin the assembly phase?
Old Feb 25, 2014 | 12:17 AM
  #69
harascho's Avatar
That will be spring.... hopefully... I still have some tasks on my to do list:
rebuilt the heater / AC box,
convert the AC to R134a,
restore the dash
get the seats done, I need new foam but have the seat covers in hand,
get the TH425 assembled and bolted to the motor
Old Feb 25, 2014 | 01:50 AM
  #70
Aron Nance's Avatar
You, Sir, are a true Craftsman! I don't remember the last time I saw lead work. Kudos for an excellent restoration, and also for your excellent patience!!!
Aron
Old Feb 26, 2014 | 04:34 PM
  #71
Jakespeed63's Avatar
Holy ***** just happened to look at this thread, partly because I LOVE these Toronado's. Saw your picture of the door jam dealer plate. This is the EXACT same dealer my 1964 Olds 98 came from!! What are the chances?? WOW.
Somehow, my car made it's way from San Jose to Orlando, Florida. We know the history of yours migrating ALL the way to Germany. Awesome progress. Thanks for sharing. You most likely have the only one in Germany??
Sorry, I only can find one picture of my drivers door. But if you were to look really close, you would see the same dealer plate.
JT
Orlando, Florida.
Old Feb 27, 2014 | 09:07 AM
  #72
Originally Posted by Jakespeed63
...You most likely have the only one in Germany??
Not quite. As I was looking up a possible registry for Germany, I came up with a couple Toronado owners: http://search.motortalk.net/?query=toronado
Old Feb 27, 2014 | 02:55 PM
  #73
Eddie Hansen's Avatar
lieber gott in himmel :-)
Harald excellent work, as was said true craftsmanship!!!! Unbelievable
Thanks for sharing and also inspiring
Killian I am not sure of the year toro but I thought the two engined 4 wheel drive toro was in Germany now? I think jay Leno also has one?
Harald forgot to say the paint is incredible
Old Feb 28, 2014 | 03:04 AM
  #74
Leno butchered his, by dropping the body shell onto a Corvette frame. It no longer has the charachter of a Toro
Old Feb 28, 2014 | 06:57 AM
  #75
Killian, I am not sure leno used the two engine Toro, and I agree it is not an oldsmobile at heart, but I will say from what I saw very well done and perhaps olds inspired is better, I did like the redlines on chromed toro wheels though, I do find it hard to say this is butchered LOL
http://www.seriouswheels.com/cars/to...o-Jay-Leno.htm
but definately not an oldsmobile per se
I was thinking this one ( I believe there are a few out there )
http://www.ronsusser.com/inventory.htm?id=846
http://www.grantpistonrings.com/hist...story_home.htm
BTW I noticed your from Freiburg, I was lucky enough to vist your city back in the early 80's I loved it, my friends uncle taught at the university, and we had a "native" guide, I still think of Ganter beer!! LOL
Harald excuse me stepping on your excellent thread!! my apologies.
Old Jul 13, 2014 | 11:23 AM
  #76
harascho's Avatar
update on assembly
Time for some assembly pics...
Old Jul 13, 2014 | 11:31 AM
  #77
harascho's Avatar
back on all 4
finally steering and brakes are connected, a new Optima yellow top with cut-out switch, a modified engine harness with relays for high and low beam and a central firewall connector with new fuse boxes inside
Old Jul 13, 2014 | 11:42 AM
  #78
harascho's Avatar
more along the way
Old Jul 13, 2014 | 12:12 PM
  #79
tru-blue 442's Avatar
Old School Olds
Very nice work!
Old Jul 14, 2014 | 04:48 AM
  #80
EightballZ's Avatar
you know that this will have an effect on the balance of your rotating assembly??
