1966 442 Front Fender & Fender Well installation
hey guys it's about time to put the front end on my car. I'm not sure of the sequence that I should use. Should I install the front fenders and then install the inner fender wells or should I install the inner fender wells first and then the fenders or finally should I assemble them as a unit on the car? I have the assembly manual to tell me attaching hardware and clearances, but I don't see where it explains the sequence.
Thanks,
Nufo (Fred)
Thanks,
Nufo (Fred)
With steel inners, you run less risk of scratching the outer fenders by installing them as a unit. It also can be hard to get all the inner fender retaining bolts lined up afterwards. You won't be installing any bolts beforehand except those running around the wheel well.
oldspackrat
February 7th, 2017 08:42 AM
costpenn
April 11th, 2012 07:25 PM
