Heater box- correct sheen?
I'm working on restoring the heater box in my '69 Cutlass. Currently it's finished in a mix of surface rust and factory black.
My question is, what is the appropriate sheen for such parts? I'm not looking at a winning show car type of finish, so flat, satin, semi, or gloss will suffice.
Is there a guide or a post anywhere as to what sheens go where on these interiors? Parts such as the e-brake assembly or anything else that was standard black regardless of the interior color (though I am switching to a black interior as well, but I'm assuming the paints/sheens are different for items such as the lower and upper metal portions of the dash).
The assembly manual will give some information on colors and the type of gloss but not for everything. The heater box will not be mentioned as far as finish but it does give info on the dash. The top of your dash will be flat black (since you're changing to black) and the lower will be semi gloss. I have found that the Krylon paint in the attached photo matches the factory semi gloss black very well. This paint is sold in semi gloss too but you want to get it in semi flat. Use this on the lower dash and your steering column and it will be as close to the factory finish as you can get IMO. Also attached is a photo of a steering colum painted with this Krylon paint.
Brian
Brian
Brian
Brian
(a fellow)Brian
Yes, use the Krylon Semi-Flat to match the OEM Semi gloss.
Brian must be more popular a name than I thought as I come across this name quite a bit. Walked into local FedEx store a few weeks back and of the 5 employees there, 3 were guys....and we all named Brian. I asked the one guy if being named Brian was a requirement for employment at that store. He got a real kick out of that...a little too much if you ask me. I'll bet that manager has her hands full...."Hi, I spoke to Brian about posters I need and I want to go ahead with that order..."
Brian
Brian
Brian
Hey Brian, can you tell me what the number is on that paint? Seems there's a bit of "controversy" regarding semi-flat black (http://www.chevelles.com/forums/showthread.php?t=307355) and when Krylon allegedly changed the formula but says it's the same. Either way, I believe those two paints mentioned in that thread are a different animal. I've been unable to locate the specific Krylon product you pictured above. So a number and a location of where you got it if you can? Thanks!
Brian
Brian
Brian
Brian, they are talking about a different series of Krylon paint and I also believe that paint was lacquer. The one I use is the Rust Tough Enamel which will also be more durable. The part number is RTA9203. I bought mine at a local auto parts store (Salvo Auto Parts) but in a quick Google search I see it's carried by Advance Auto and Sears. Check your local auto parts stores if you don't have a local Advanvced Auto. I also see it's sold by Summit Racing and on Amazon. We'll keep this little secret to ourselves and will let the Chevelle boys continue to drive themselves into a frenzy!
Brian
I thought I'd chime in to add to the Brian roster, as well as add to the semi-flat/semi gloss topic. I have also used the Rust Tough Krylon paint with great success. The only difference is the cans I bought were part number 49203 here in Canada. I have also used Duplicolor semi gloss with good results, albeit slightly shinier, still very nice. I have enclosed pictures of before/after after my recently completed heater box. I believe used the Duplicolor paint. Either way, I think you'll be happy.
c-towndave
May 3, 2015 07:55 PM
Texas442
Nov 27, 2009 05:01 PM
