Sound/Noise deadening material
Old Jul 30, 2012 | 07:43 PM
61reoldsman's Avatar
What material have most people used under their carpet to quiet the road noise?
I see that the original jute material can be bought and installed but are there alternatives that may be better /and or cheaper ?
Old Jul 31, 2012 | 01:20 AM
garys 68's Avatar
very happy with fatmat. dont even bother with the pre-cut "tarpaper" stuff the Olds part places sell, it's worthless
Old Jul 31, 2012 | 02:02 AM
cut123's Avatar
agree
Old Jul 31, 2012 | 02:37 AM
bdub217's Avatar
Kickin' It Oldschool
x2 ^^^^ I've used fatty matty to cut vibrations down in trunks with bass =0 I used to install car audio out of my garage for a living.
Old Jul 31, 2012 | 02:47 AM
Alex72cutty's Avatar
Fatmat huh!! How about a website? Thanks!! O.... sorry for hijacking...
Old Jul 31, 2012 | 02:54 AM
bdub217's Avatar
http://www.fatmat.com/
Old Jul 31, 2012 | 03:13 AM
Thank you!
Old Jul 31, 2012 | 05:32 AM
garys 68's Avatar
check ebay for the best prices.
Old Jul 31, 2012 | 07:03 AM
what about the stuff from B Quiet ?
Old Jul 31, 2012 | 07:11 AM
Lady72nRob71's Avatar
I did a thread a while back called "dynamat - worth it or a waste" that could help you.
Most of these similar products are okay, just avoid ones that use actual tar in them, unless you just love the smell! It melts in hot cars, too. This rules out most roofing stuff.
The dense heavy sticky stuff dampens vibrations and noise and the foamy stuff insulates from heat.
Old Jul 31, 2012 | 07:28 AM
kanskidoo's Avatar
I've used dyna-mat in cars before and it works great, although it is kind of expensive, especially the type that is foiled on both sides. If you have a Lowe's or Home Depot (probably most places like that carry it), they carry a "foil both sides" material for use in houses that works just as well and is about half the price.
Old Jul 31, 2012 | 11:26 AM
bdub217's Avatar
You could get away with using carpet padding in the door panels and behind the rear seat wall. This would be super low budget i need something anything will work type deal though. It wont be as effective as the real deal but should do some good.
Old Jul 31, 2012 | 05:57 PM
ziff396's Avatar
I used Fatmat extreme and was about 1/2 price of the Dynomat on epay. I am very happy with the results.
Old Jul 31, 2012 | 06:52 PM
Foil both sides ,yes i saw that stuff I have it on my inside garage door ,not bad ,insulates fairly well
Old Aug 1, 2012 | 01:16 AM
garys 68's Avatar
That's Refexit, or something like that. Great for temp insulation, does nothing for sound.
But if you really want to go all out.
Fatmat
Reflexit over the fatmat
The worthless tar paper stuff I already paid for over the reflexit
Heavy rubber, jute backed firewall insulator;
Then the jute backed carpet over that.
Old Aug 1, 2012 | 03:21 PM
That looks like it should be nice and quiet
but with all those layers how does it affect
all your interior pcs going back in like the kick
panels and your door sill plates ?
Old Aug 1, 2012 | 04:23 PM
bdub217's Avatar
it compresses enough to get all the panels back on, you may have to push a little harder than normal.
Old Aug 2, 2012 | 06:58 PM
well it will be a while before I get to using one of these products as I need to replace some metal in the floor first ,got some cooling holes that shouldn't be there !
delta_88_germany
Jan 11, 2015 01:34 AM
ragtop70
Sep 3, 2012 10:15 AM
ztim
Jul 10, 2009 05:28 PM
tclaemont
Nov 27, 2008 05:50 AM
Rallye469
Feb 6, 2008 11:42 PM
