dash removal
Old Feb 29, 2012 | 08:47 AM
centonze's Avatar
dash removal
I have a 69 442 and I am trying to remove the dash. Does anyone know any tricks or ways to make it easier to get the nuts off of the dash where the air vent is? I can't seem to fit my hand and wrench to the area where the stud and nut are. Any tips to remove the dash would be appreciated.
Old Feb 29, 2012 | 09:00 AM
allyolds68's Avatar
There's no easy way to do it. There's also a stud between the speedo and the clock that doesn't have a nut. It's push-in, friction fit You have to pop that with a hammer and a long extension. Sometimes I've also found a ground cable that gets installed after the dash goes in that hangs up on the dash metal & has to be removed. Not sure if that's from the factory that way (I don't think so) but sometimes wires get installed and/or changed later
mrnursedude
Nov 12, 2019 03:27 AM
Bryan59EC
Jun 3, 2010 10:36 AM
77 oldsMAbrotha
Sep 23, 2008 05:00 PM
dholmes898
Jul 9, 2007 09:13 PM
mich77442
May 14, 2007 11:39 AM
