installing original radio in dash again?
So my latest project has been to replace the dash wiring ( which was previously spliced and melted beyond recognition ) and the dash itself.
The dash I had previously the p.o had cut a hole to fit an aftermarket radio. The new dash i have has never been cut. I have the original am radio but I am failing to see how it would be mounted.
I'm guessing im just missing the brackets needed to secure factory radio. Anyone have any suggestions or pics on how i might get this back in there?
thanks in advance
steve
thanks in advance
steve
The factory radio was mounted using the nuts on the radio control shafts and a cheezy plastic strap on the back that connected up under the dash to where the middle AC vents are.
When I got my car, there were no back mounts so I fabbed a metal bracket that secured it to the lower metal dash structure.
No rear support will eventually damage the dash, and radio and cause annoying squeaks and squauks while driving.
Unfortunately I have no pictures of that creation... Just use your imagination I suppose.
There's supposed to be a bracket to the dash, my car has that and the strap.
Maybe they use that nylon strap to to dampen shock and vibration and to allow some flexibilty so the unit isn't damaged?
It seems like they would of just used another steel bracket otherwise?
I think that metal bracket that mounts between the back of the radio and the bottom of the dash is also supposed to serve as the ground connection for the radio. I also vaguely recall that behind the plastic facia on the dash there is a thin metal ring through which one of the **** stalks protrudes.
Another thought just depends on your build goals.Currently on the 64 F-85 "Post" build I plan on installing the restored orignal AM radio but with a resto-dual speaker 4&10 modern front speaker for weather and info purposes. I'm going to mount the Rev-Limiter in the glove box for the bad boy.
The dual was for getting two channels (stereo) from that one speaker.
I bought a Retro radio and it mounted the same way. My dash was cut so I used the metal bracket from a 69 Cutlass.I used the metal bracket that came with the radio.It sounds great and it came in without the antenna hooked up!
So got the radio in today, found some replacement ***** on ebay. For whatever reason they did not work, maybe the radio i have is not originally from 70 cutlass oh well with a little persuasion, i made them work anyways.
the kit i found also had the dash speaker bracket i used that under the radio in conjunction with the factory lower brace and it turned out ok i think.
eventually will go with a retro radio but for now this works just have to put this old alpine in glove box for now, maybe tomorrow morning time for some weekend refreshments
1badcut
Feb 13, 2011 06:27 PM
