Buckets
Old Jun 6, 2026 | 08:50 PM
wills30's Avatar
Buckets
Are the bucket seats in a 65 64 wider than the 66
Old Jun 7, 2026 | 07:21 AM
Can we assume you're referring to A-bodies?
Old Jun 7, 2026 | 08:22 AM
wills30's Avatar
yeah.
sorry 64 cutlass to 67 cutlass, when did the trim differ
Old Jun 7, 2026 | 08:51 AM
66SportCoupe's Avatar
64 and 65 are the same. 66 is a big change to the strato bucket but has no back locks. 67 is the same as 66 but HAS back locks. 68 and later are wider the the 66 to 67. Don't ask how I found that one out.
Old Jun 7, 2026 | 09:04 AM
wills30's Avatar
by photos they did look different. But similar
Old Jun 8, 2026 | 08:24 AM
RAMBOW's Avatar
Ben
Just want to make a correction... 66-72 buckets have the same basic overall dimensions. 68+ is not wider.
Springs, buns & covers can all interchange between 66-72.
Yes, there are subtle differences between years and models, the seatback locking mechanisms, headrest style and mounting, even some unique upper cushion spring assemblies for certain years/models, definitely tracks can be unique between body styles- but overall dimensions are the same.
64 and 65 have their own unique issues... A-Body 64-65 seats do use the same frames, however the lower spring assemblies are different depending what the original car was. Chevelle Lower cushions have rounded front corners where as Buick/Olds/Pontiac had "Pointed" front corners of the lower springs. Luckily it seems (in my experience) there are way more of the BOP 64-65 buckets than the Chevy versions... But be aware, if you tried to put BOP covers on a chevy lower spring assembly it would not fit right.
64-65 "Chevy" Style lower cushion spring assembly- Note the front corners
64-65 B-O-P lower spring assembly, Note the front corners.
To make it more complex, the 64-65 a-body seats LOOK like the seats used in 62-65 Chevy II, F85, Corvair and a few others, however they are NOT THE SAME. Those are actually wider than the A-Body seats, so covers and buns and stuff won't interchange.
There are a LOT of those seats for sale listed as a-body seats, don't be fooled. The way you tell is to count the main springs visible on the underside of the lower cushion.
True A-Body 64-65 seats will have 4 main springs. ChevyII,F85,Corvair seats have 5 Springs across the bottom. B-Body (fill size) buckets from that era also look similar but are even wider still, those also have 5 springs across the center.
True 64-65 A-Body Seat, 4 main springs visible on the bottom (can count the retainer tabs at the front of the frame to be sure)
62-65 ChevyII,Corvair,F85,Skylark, etc seat: 5 Main springs visible across the bottom:
Actually remembered yet another random detail someone sent me... 65 corvair seats actually ARE the same as a-body (4 main springs) but the earlier ones are the wider ones.
So all that to day, if you are buying 64-65 seat cores to restore- count the springs!!!
Anyway, hope this info helps!
-Ben
Old Jun 8, 2026 | 08:51 AM
wills30's Avatar
-Ben
so .im looking at some 66. And I have anther set that came with the car . But not certain what they came out of. But this information, i should be able to get an idea of where or what they are
thanks
Old Jun 8, 2026 | 09:08 AM
@RAMBOW , that is an incredible primer on GM A-body seats over the years. Thanks for posting!
Old Jun 8, 2026 | 09:15 AM
I'll bet you you can not hang a 68 seat back on a 67. That's why they are listed differently.
Old Jun 8, 2026 | 09:28 AM
RAMBOW's Avatar
Ben
thanks
Well, no- Those pics and details are related to 64-65 seats
66-67 seats have their own unique details, but here are the primary ways to identify what you are looking at:
  • 66/67 "should" have metal sides and back panels with imitation vinyl grain stamped into them
  • 66 will have no seatback lock, it just flops forward.
  • 67 & 68 have a seatback lock with a chrome release button on the outside edge of the upper seatback
  • 68 Has plastic sides and backs, headrests are extremely rare as it was optional
  • 69-72 has a seatback lock with a large plastic chrome release button in the center of the upper seatback. These all came with headrests.
basically any 66-72 seat can be turned into a 66 seat by removing the seat back lock mechanism and putting a 66 back panel on it (without an opening for the release button) and removing the headrest components.
67-68 are harder to find, 69-72 are the most common.
Some various 66 Pics to help....
Old Jun 8, 2026 | 09:34 AM
RAMBOW's Avatar
Ben
You absolutely can, just need to fab the 68 style back panel hooks. They both screw onto the back of the frame, you just need to know or work out the mounting location.
Same thing the other way around if you want to put 66/67 backs on to 69-72 frames, you just need the 66/67 style hooks.
68 style:
66/67 Style:
Old Jun 8, 2026 | 04:31 PM
wills30's Avatar
Thanks for your detailed review. Like what was stated. If you look at the chevelle seats. They look more fuller or boxy.
maybe that was throwing me. Then , it was posted that 68 seats don't fit 67 frames . Overall thanks for the information
Old Jun 8, 2026 | 04:37 PM
Okay. For someone who doesn't have a dozen pairs of buckets the correct information is that seats don't fit other years unless you have multiple different year seats to manipulate something that is incorrect. The correct information is what people need.
Old Jun 8, 2026 | 05:01 PM
wills30's Avatar
well 66. Sir. I don't have multiple seat.
I just questioned. Because they looked different. No biggie, I believe we can all agree that the 65 seat can't inchange with 68 parts. But the information provided. Which I can't question. But i can use as a reference.
Old Jun 11, 2026 | 08:23 AM
REO442's Avatar
Rest easy, boys! Given the fact that Rambow is darn good at what he does, he will send you in the right direction. Sound information is your friend.
Old Jun 14, 2026 | 07:06 PM
wills30's Avatar
any idea what yrs these may be
Old Jun 14, 2026 | 07:19 PM
Those look like '68-9 Firebird seats.
Old Jun 14, 2026 | 07:29 PM
wills30's Avatar
I just looked up seat covers for 69 .
and they are a match.
Old Jun 14, 2026 | 07:36 PM
A match for what?
Old Jun 14, 2026 | 07:51 PM
wills30's Avatar
69 firebird
Kgxqg0
Jun 14, 2026 04:02 PM
Leechristensen
Jun 22, 2020 06:15 PM
kjr442
Jun 16, 2015 07:33 PM
lunaboy
Sep 12, 2013 03:55 PM
ferndaleflyer
Jan 21, 2012 05:28 PM
