What does this do?
Old Mar 28, 2014 | 04:02 PM
Desperado's Avatar
What does this do?
I have a 1967 442 and on the turn signal stalk ther is a black button on the end. Oldsmobility said it's for cruise control. Can someone please tell what it is? Thanks.
Old Mar 28, 2014 | 04:13 PM
Maybe, post a pic. Cruise stalks varied quite a bit over the year. The button on most cruise stalks is the 'set point' signal to the transducer to hold that vacuum setting.
Old Mar 28, 2014 | 04:15 PM
It was for the rudimentary cruise control.
Old Mar 28, 2014 | 04:20 PM
Does the stalk look like this (from 67 Cutlass Assembly Manual)? Eric, never asked you if your 67 had cruise?
Old Mar 28, 2014 | 04:30 PM
No mine doesn't, I believe they are pretty rare for the 60's in general. Plus I'm old school I like to operate the fun pedal. I think in the last 25 years, I don't think I've used cruise 25 times.
Old Mar 28, 2014 | 04:55 PM
Desperado, can you find evidence of cruise control hardware in the engine compartment? There should also be a dash switch somewhere (likely on the left side of steering colum) to turn cruise on/off
Old Mar 31, 2014 | 02:14 AM
Yellowstatue's Avatar
'68 and earlier Cutlass did not have off/on switch.
Old Mar 31, 2014 | 04:47 AM
You mean it was always on? That just sounds wrong.
Old Mar 31, 2014 | 05:54 AM
brown7373's Avatar
It's only on when you push the button. I always have thought that is redundant. Like having a separate on/off switch on the wall to turn on, so the regular light switch on the wall will turn on a light.
Old Mar 31, 2014 | 06:17 AM
So how does it turn off? Does it disengage with brake application? Sounds like a confusing system.
Old Apr 1, 2014 | 03:06 AM
It is extremely high tech. Push button 'ON' Step on brake 'OFF'
Old Apr 1, 2014 | 09:58 AM
Wow, high tech it is! "On" then not only turns the unit on but creates the set point signal for vacuum. That would be enough to confuse most blondes I know. ON/OFF. Why would anyone want something more complicated??? Why that's almost as bad as trying to explain the need for 710.
Old Apr 1, 2014 | 10:04 AM
The system does not have a speed compensator or any way to increase or decrease speed electrically. It was a basic vacuum actuated throttle positioning locking mechanism. Like I said very rudimentary system compared to todays. I remember when you could buy a similar aftermarket basic cruise control from anywhere.
costpenn
Aug 29, 2018 11:42 AM
hoppers69
Apr 30, 2012 06:55 PM
SMOKEYMTNKUSTOMS
Dec 26, 2010 09:51 PM
<lkajdf>
Cars Wanted
Jun 29, 2007 02:49 PM
