Split bench in a car with a solid bench?
Old Nov 23, 2013 | 05:38 PM
Dead Reckon's Avatar
Rocket "Scientist"
Is it possible to put a split bench seat in my 1977 Delta 88 when it only has a solid bench? I need another seat, and I've been told it isn't possible without welding in studs, is that true?
I'm thinking of doing some work to this car and keeping it, it's pretty light, it's plenty quick, but I miss my split bench seat.
Old Nov 23, 2013 | 07:25 PM
It depends on what year and body style the new seat came from. Any seat can be installed in any car with a bit of creativity.
Old Nov 24, 2013 | 02:30 AM
nsnarsk65cutlass's Avatar
If it's out of the same year range model 2dr vs 4dr i think 77-mid 80s are the same and will bolt up.
Old Nov 24, 2013 | 04:46 AM
Rocket "Scientist"
Well, 77-84 or 85-ish where full size, rear wheel drive, for teh Delta 88, and 77-89 for the Custom Cruiser, both fit, both have the exact same dash as mine. I actually have hte plood bezel for the 1.5 DIN radio out of my '89 custom cruiser so I can install a modern stereo without cutting the dash panel.
I know that this stuff fits, I just don't know if they did not add studs to the floorboard or some other whacky GM nonsense, I mean, it didn't have rear speakers, so, there is no rear speaker wire. Not that it could be used if there was, rears used a common ground, wired in mono. Just using that as a reference to what companies like to leave out.
Basically, I'm just curious if there are actually studs in the floor with which I can mount the seat too. As I said, I know that GM is of the mindset of "If it isn't being used, don't install it, it saves us 1/5th of a cent per ten cars!"
Old Dec 8, 2013 | 03:23 PM
cadillac kevin's Avatar
you will need to drill into the floor or weld studs into the floor for the inner 2 mounts on each seat. GM did not include those studs unless you got a split bench. any seat frames from a 77-90 B/D body will work
4-ever-olds
Nov 14, 2017 05:56 PM
Wildcard
Mar 25, 2013 02:03 PM
yeahbuddy
Dec 16, 2011 06:23 PM
69442
Oct 13, 2011 04:38 AM
Chumley
Sep 25, 2011 07:43 PM
