Sienna Vinyl Dye
Die or Paint?
If you are looking for paint there is no perfect match on the market.
I went through about 4 custom color matches before i settled on the color i used.
It is an old GM interior color 1985 Russet 68CN from Dupont
for one pint
884J LS Red Oxide 50.8
802J LS White 68.7
806J HS Black 73.7
304S Low Gloss Vinyl Clear 419
For Med Gloss replace 304S with 305S
For High Gloss replace 304S with 306S
Low Gloss Mix seems too flat for interior metal parts and vinyl. I went with the low gloss and had to clear it to get some gloss back. The next batch i order will be medium gloss. I recommend the medium gloss.
This has no metal flake so it will not work on exterior. The exterior is harder to match. Somewhere i have a code for a mid 80s Nissan color that is the closest i have seen to Sienna.
I am in the process of restoring a tilt colum, here is a pic of the color.
for one pint
802J LS White 68.7
806J HS Black 73.7
Hurst/Olds 73/74
Oct 23, 2012 06:30 AM
slowolds
Jun 14, 2010 09:40 AM
