Shifter lever connection
Old November 11th, 2017 | 04:29 PM
GreekDog's Avatar
My shifter lever has never worked ever since I got my 72 cutlass. I pulled the speedo and i see the clip but I don’t see where to attach it. What am I supposed to be looking for guys?
Old November 11th, 2017 | 04:55 PM
CRUZN 66's Avatar
Olds Fever
It appears you are missing the cable that clips to the shifter collar on the column... May look something like the one in the photo below...
Old November 11th, 2017 | 07:44 PM
GreekDog's Avatar
Yeah I don’t have that piece. Do I attach that from the inside before I mount the gauge? It’s such a tight squeeze. I can’t imagine getting the Speedo cable connected and then somehow connect long that cable .
Old November 12th, 2017 | 08:11 AM
That is not how the shift indicator link is connected on the 68-72 cars. The diagram is in the STEERING chapter of your Chassis Service Manual. The steering column outer tube has a square hole below the speedo. This hole lets you see the inner shift tube that rotates when you move the shift lever. A clip snaps into a smaller hole in the shift tube. A hook attaches to this clip with a sheet metal screw and this hook is what the lower end of that wire link in the first photo attaches to.
Old November 12th, 2017 | 12:50 PM
2blu442's Avatar
Here's some pictures of the clip Joe's describing attached to a 70-72 steering column. You might check the location on your column to see if its still there. John
Old November 12th, 2017 | 04:25 PM
CRUZN 66's Avatar
Olds Fever
Sorry for the confusion... Had a senior moment and was thinking of my G-Body shift selector setup and not the 72... Chassis manuals are definitely your friend, I should have double checked my sources before posting...
jensenracing77
December 21st, 2014 09:18 PM
nelsontj
August 22nd, 2013 10:55 PM
Flye
April 1st, 2013 11:13 AM
olds70supreme
January 27th, 2013 05:09 PM
halfmoontrail
January 9th, 2013 10:17 AM
