shift indicator on column shift hook up?
Does anyone know how the shift indicator on column shift hooks up to the speedometer, the column was out of my car at some time and it was never reinstalled.
Jeff
Jeff
Hi Jeff
What year/model of car? Its probably a thin wire that's bent into a hook that attaches to an arm on the speedometer head. Then the other end is attached to the column by a clip that's bolted on. I'll see if I can find a photo of this on a 1970-72 Cutlass. John
Sorry Jeff, I lost track of your request. Here's a series of photos showing the hook attached to the column, then a loose speedometer head with the white plastic lever that the wire hook attaches to.
I probably have extras, but I'm not organized enough to know where they are I'd encourage you to create a parts wanted thread and your welcome to use these photos or link to this thread if you'd like. Good Luck! John
Ok I actually found the column attachment in a box of parts. Now I guess I need the length of the rod!! Do you think steel TIG rod is strong enough to make the linkage rod out of? Thanks!!
Jeff
Jeff
starfire
December 9th, 2021 08:21 PM
Rocketbrian
October 2nd, 2013 10:18 AM
Bitburger
December 30th, 2012 04:49 PM
projectheaven
January 8th, 2012 09:17 AM
ros6872
February 24th, 2010 05:50 PM
