Are seats interchangeable?
Old Apr 20, 2012 | 04:44 PM
TenMidgets's Avatar
Have had thoughts of swapping my '69 off-white front bench seat for a pair of black buckets from a '68 and a replacement black rear bench from a '72. Would these just bolt in or would modifications be necessary?
Thanks!
Old Apr 20, 2012 | 05:02 PM
You need different seat mounts/slides going from bench to buckets. But the back seat should be a straight across swap as long as the donor is not a vert.
Old Apr 20, 2012 | 05:05 PM
TenMidgets's Avatar
Cool, thanks Allan.
Old Apr 20, 2012 | 05:19 PM
Jonb442's Avatar
Hi,
The '68 seats will bolt in (after installing bucket seat mounts), but the seatback release is different than that on '69-'72 buckets. Also difficult to add headrests if you want them to the '68 seats.
-Jon
Old Apr 21, 2012 | 06:08 AM
Chesrown 67 OAI's Avatar
Smile
Thanks!
I would be interested in buying your front bench seat if you decide to do the conversion. I'm looking for one i can recover for my 68 Cutlass
Old Apr 21, 2012 | 11:24 PM
RAMBOW's Avatar
Ben
The 71/72 bench seatbacks are a slightly different shape & internal design than the earlier ones- may be difficult to install the early covers on the two seatback peices.
Look for one that comes from a 70 or earlier car, and the 68 covers will install w/o a problem.
Old Apr 22, 2012 | 05:50 AM
Thanks for answering my question before i asked it!! So you say a 70 bench is same for 68 and 68 seat covers will fit on it? Great to hear because I think i have located a 70 seat! Thanks again!!
anotherfallingstar
Ninety-Eight
Jun 24, 2007 12:53 AM
cutlassjack
Jun 18, 2007 09:33 AM
plasma98
Brakes/Hydraulic Systems
Apr 20, 2007 12:06 PM
83olds88
Mar 14, 2007 12:09 PM
Edveen
Nov 6, 2006 09:53 AM
