Sail panel dome lights on a non-supreme?
Old Jul 6, 2013 | 11:12 AM
White_Knuckles's Avatar
I'm replacing the windlace molding on a '67 Holiday. I peeked and felt under the headliner looking for shoulder belt mount points (which I don't think are there) and found wiring on both sides heading towards the rear.
There are pairs of white, small ga. wires on each side. Could they have pre-wired these cars for those round, rear courtesy lamps mounted to the sail panels on supreme's? If so, repops are fairly cheap and I could add 'em. Cool upgrade.
I can't figure out why any wiring is present up there? This car keeps revealing surprises!
Old Jul 6, 2013 | 01:57 PM
I suspect they were wired in from the factory. Harnesses in the 60's and 70's were pretty generic, so that allowed owners to purchase and install OEM accessories at their convenience to an already existing harness. I have 5 1970-72 dash harnesses and all of them are exactly the same, even though they came out of different optioned cars. I would say if you intend to install the sail panel lights, it should be an easy upgrade. Most of the sail panel light packages I've seen and have use a double wire, but one is orange and the other is white.
Old Jul 7, 2013 | 10:39 AM
Thanks Allan_R, the wire pairs indeed may be Or/Wt. I couldn't imagine what else they would feed.
68cuttysupreme
May 1, 2018 01:43 PM
m1369d
Body work
Feb 15, 2014 12:41 PM
onofre442
Dec 1, 2013 10:36 AM
2blu442
Nov 6, 2010 09:13 AM
76CutlassSupreme
Jun 11, 2010 04:28 PM
