Replace antenna base on 66 442
I need to install a new antenna base and mast on my 66 442. It looks like I need to remove the cowl or maybe the inner wheel well I am not sure. Please let me know how to install this it would be greatly appreciated.
Many moons ago when I changed antennas I loosened the mast nut and the braket under the fender swung around and the antenna pulled up through the hole. I would cut the old coax and strip back the wires and wrap the new plug with them and tape it. Then I would pull the old coax from the passenger compartment to guide the new cable though. Then remove the tape and the old wire and connect it to the radio.
