Removing door panels
I am trying to remove the passenger side door panel and I have removed all levers, screws, fittings but I am stuck as I don't know how the remove the top portion of the door panel and I do not want to damage it in the process. Any special tools needed?
Steve
Steve, I did all of that but it seems hard to pull the top portion off the door and I do not want to damage the door panel in the process. Are they any plastic pins under the top portion of the door panel?
There is probably a plastic pin a few inches down from the window track on each side.
eudaman
May 19, 2013 05:30 PM
