Recover front buckets
Old Apr 7, 2010 | 04:39 PM
tim72's Avatar
Just wondering how easy or hard it would be for an amateur like myself to put replacement covers on the buckets. I have bought the foam and material from a reputable source. any tricks to the trade like steam?
Old Apr 7, 2010 | 05:25 PM
kaz442's Avatar
I did it once, Only take one apart at a time so you have the other for refernce of where clips and such go. You will need the metal rods out of the old seat cover and install them in the new cover. I used a heat gun on low setting and kept it moving for the hard to stretch areas. I have heard to put the cover in the sun to soften it up also works. One tip I learned after the fact but never tried was to use a plastic garbage bag over the foam to let the cover slide easier and then remove when done. Sounds like it should work. Hemmings Muscle did an article a few months back that was pretty informative also.
JKaz
Old Apr 7, 2010 | 06:01 PM
Olds luvr's Avatar
Grown Azz Kid
Tim72...
I am in the process of doing mine now. You can see my progress in my thread "interior gutted with questions"
Also look at this.... http://www.buickperformance.com/bs.htm
Good luck and hope it is not too hard for either one of us
73 Olds Cutlass
May 12, 2013 06:42 AM
ros6872
Aug 28, 2012 09:43 AM
AzChevs
Mar 22, 2012 12:40 PM
davepnola
Dec 4, 2011 02:18 PM
Olds luvr
Feb 3, 2010 07:46 PM
