Power bucket control location on seat side
Old May 24, 2009 | 06:34 PM
68conv455's Avatar
I've redone the power bucket seat in my 68 cutlass. The used plastic side trim pieces I cleaned up were from a non-power seat. Can any of you provide the approximate location where I would cut the hole to mount the seat adjustment lever? Thanks.
Old May 24, 2009 | 07:48 PM
rocketraider's Avatar
Oldsdruid
Look on the back side and see if there are any guide lines moulded in for the power seat switch cutout. That's what they did with the consoles rather than have separate part #s for automatic, dual/gate and stick. I kinda doubt GM had two different parts for power and non-power seat side trim.
Other than that I can't help. My Toro with Strato-Bench seat uses the same trim pieces but it has a 6-way seat.
Old May 24, 2009 | 10:18 PM
Yellowstatue's Avatar
Pwr switch
Also, on the metal frame of the seat, is a rectangular hole where the switch & plug sits...this will give you an idea of where to place the round hole for the switch.. you could use a hole saw, but it would need to be dressed after the cut or you could use a Greenlee punch for a nice clean incision... I just checked several of my seat trims and none of them have any guide lines, so they must have used a jig at the factory...mount the switch into the seat and then guesstimate where the hole should be and make a tiny hole to see how correct you are and then continue from there...two small holes for the attatching screws also...
Old May 25, 2009 | 09:33 PM
2blu442's Avatar
I don't know if this will help, but here's a few pictures of one that I have. It looks like the greater challange will be getting the screw holes in the correct place. As Yellowstatue said you can start with a small hole for the control ****. John
These two are measured from the front.
These two are measured from the rear
I also compared this to the 6 way controls on a full sized and they're in a different location. Let me know if there's anything else here that could help you. John
Old May 27, 2009 | 03:58 PM
68conv455's Avatar
Thanks for the info and effort. But now I'm confused. Not on the location because you have given me some good ideas and a reference. I'm confused on my power seat control. My control has a chrome face, making me think it installs on the outside of the seat trim. Not on the inside. I've enclosed a picture for your comments. Is this correct for a 68 cutlass?
Old May 27, 2009 | 05:25 PM
Texascarnut's Avatar
Geezer
Are the locations for the mounting screws for the assembly threaded? If so what you have would go behind not on top of the seat surround. It being bright plated does not necessarily mean it was intended to be mounted on the outside.
Old May 27, 2009 | 06:30 PM
2blu442's Avatar
I've had these apart before and yes it is correct for that to be behind the plastic. Even with the nice chrome finish. John
Old May 28, 2009 | 02:50 AM
Smile Too shiney
X2-- The only thing that shows is the knobby and the shiney ring!!! I haven't been into mine lately but I think there are J-nuts fitted to the seat frame for the screws to grab (philips- just like in the picture)
Old May 29, 2009 | 07:29 PM
Jonb442's Avatar
The switch bezel is chrome because it mounts on the outside on power bench seats.
-Jon
69442murph
Jul 9, 2014 04:55 AM
70Post
Mar 15, 2014 11:28 AM
65cutlassnorth
Sep 11, 2013 11:00 AM
craftsman1956
Aug 13, 2010 09:48 PM
KZ442
Apr 10, 2009 03:16 AM
