Never ending fun of the daily driver - heater core
Old Feb 25, 2013 | 06:46 AM
Well after 46 years my heater core sprung a leak. Now all I have to do is find time and crawl under the dash to see how to get the bugger out of there.
They seem to never go out in the summer, lol!
Old Feb 25, 2013 | 06:58 AM
tru-blue 442's Avatar
Old School Olds
I did one on a 67 Cutlass once.
Wasn't too bad, but then again I
didn't have to deal with a/c either.
Are you guys getting hammered by
the storm this morning?
Old Feb 25, 2013 | 07:07 AM
no storm issues here in the DFW area. Mine is a no a/c car.
Old Feb 25, 2013 | 08:02 AM
RandyS's Avatar
IIRC, you will have to take the heater core housing off from the firewall side. One nut above the fan motor is almost impossible to get to...........
Old Feb 25, 2013 | 08:32 AM
I thought it comes out from the inside of the car
Old Feb 25, 2013 | 10:21 AM
droldsmorland's Avatar
CH3NO2 LEARN IT BURN IT
Wink
Oldcutlass you know the drill pull the front passenger seat out so you can lay down in comfort especially if your as old as the car.
Old Feb 25, 2013 | 10:48 AM
I think you're right Eric. The in/out hoses are attached from the engine bay, but it looks like you have to take the heater box out from inside the car.
Old Feb 25, 2013 | 11:06 AM
TripDeuces's Avatar
You're probably fighting with the console too if you have one
Old Feb 25, 2013 | 11:30 AM
I'm older than the car, and a bench seat. Thanks for the diagram Allan. From the looks of it I have to take the nuts off the studs through the firewall and then the box falls out fom the inside. That makes sense.
Old Feb 25, 2013 | 11:49 AM
Eric you kill me! Most of us are older than your car. I was 14 when I learned to drive on our 67. Ooooops, I keep forgetting about the younger crowd.
Anytime. That's my take on it too. Pretty much the same as my bench seat 72 (which we both know now we're way older than)
I'm not sure but I think you'll have to disconnect the slide cables for the heater too.
Old Feb 25, 2013 | 11:57 AM
bccan's Avatar
Tuck an unloved towel or something absorbent between carpet/padding & firewall so no drips soak in creating a lingering smell.
Old Feb 25, 2013 | 11:58 AM
The age statement was for Eric. Lately we've had a few youngins poppin in here.
I only take apart what i need to. No maw's <crosses fingers>
Old Feb 25, 2013 | 12:06 PM
Seff's Avatar
What youngins? Heheh.
I fought with pulling the heater box out straight when I pulled apart my '71, it kept snagging on one end and bending the studs. The bent water pipes don't make it any easier.
But hey, daily drivers are the best.
Old Feb 25, 2013 | 01:44 PM
What?? More Eric's on this site than you can shake a stick at
Old Feb 25, 2013 | 04:52 PM
I know thats why i don't use it in my sig, I'd confuse me.
Old Feb 25, 2013 | 05:05 PM
scooter123's Avatar
Did mine a few weeks back on the 88.....it was easy getting it out but when putting it back one of the 4 bolts got a little tweaked and it would not line up right.....a few cuss words and a few attempts I got it!!!
Old Feb 25, 2013 | 05:31 PM
ah64pilot's Avatar
Eric, plug the heater core inlets (where the hose connects) on the inside with some paper towels...as you remove it rotate it so that they point up. You won't lose a drop, except for the place it is leaking from. They're easy, have fun
Old Apr 6, 2013 | 09:57 AM
Ok, just an update. Finally decided to tackle this today. There is one stud that was a biatch to get to, the lower 1 behind the wheel well. All in all it wasn't too bad and this is one time I'm glad that the car is a no air car. I have one coming from O'Reiley should be here by 3. Hopefully it's the same!
Old Apr 6, 2013 | 05:30 PM
Seff, my original heater core had straight upper and lower tubes, however like yours the lower one had a 45 degree bend toward the outboard side and angled up a bit. It was a PIA and after about an hour and a few appropriate cusswords, viola, it popped into place. Again I'm glad it was not an A/C car.
Old Apr 6, 2013 | 05:34 PM
Seff's Avatar
I rolled my eyes and made the hole bigger. :P
Old Apr 6, 2013 | 06:29 PM
That was cheatin, however I did consider that.
Old Apr 7, 2013 | 01:15 AM
Seff's Avatar
I had already converted my firewall from AC to non-AC, so the grinder was lying RIGHT there... Too tempting.
allyolds68
Jul 28, 2013 11:50 AM
RockAuto
Aug 3, 2012 08:48 AM
VikingBlue
Jun 8, 2012 11:40 AM
ROBZ442
Aug 23, 2011 10:53 AM
nonhog
Sep 10, 2010 11:16 AM
