Installing carpet
Old Jan 11, 2015 | 01:22 PM
tdhill01's Avatar
Installing carpet
Hi, I'm going to be installing new carpet in my 1971 cutlass convertible and though it is not a show car it is a nice daily driver during the warmer months in the northeast. I am not looking to deaden the sound because it's a convertible but is there any issues if I just lay down the new carpet which has a jute backing, trim it and put the seats back in? If after taking my old carpet out and I find I need to do some repairs I will take care of that.
Tom
Old Jan 11, 2015 | 01:29 PM
mrolds69's Avatar
There shouldn't be any issues, but there may be. You can't really tell 'til you try it. The sound proofing had some thickness, AC cars usually had an extra pad, the original jute was thicker than repro. Some carpets are cut a bit short on the sides near the vent panels. ACC + Trim Parts usually fit well, regardless. You can re-use the old jute, peel it off if needed, in addition to what's on the carpet. Sometimes you have to pad certain areas.
Old Jan 11, 2015 | 01:40 PM
dc2x4drvr's Avatar
Couple tips
Use a soldering iron to make holes for the seat belts and seat mounts
Unroll the carpet so the big wrinkles smooth out, I've used a spray bottle to help the carpet smooth out
Make sure the carpet is fitting tight against the hump before doing any trimming
Just my .02
Old Jan 11, 2015 | 02:33 PM
tdhill01's Avatar
Thanks for the tips guys. The carpet is from Trim Parts and I like the idea about the soldering iron to do the holes.
Tom
milesmonte
Mar 23, 2015 07:31 AM
andrewk94
Sep 7, 2012 03:34 PM
ctreutel
Jul 4, 2009 03:39 PM
eightyeight394
Aug 29, 2007 11:22 AM
68Toro71442
Jan 20, 2007 03:45 PM
