inside door panel clips for '68 98
Hi All -
Has anyone know how to remove these clips? And also does anyone know where I could buy some of these - there tough buggers to get off (made of spring steel and attached to plastic tables that hold part of armrest to the door panel on a '68 98 LS 4dr.
All thoughts and info is extremely welcome!!
- beepac
- beepac
Just use a small flatblade and press back (twist) against the spring section. That's how I did it on similar clips on various cars. If you're careful you can reuse the clips because the spring steel doesn't usually lose its memory. That's very similar to the clips on some newer car door panels.
