Door deadener
Old Mar 3, 2020 | 01:08 PM
Mossy's Avatar
Door deadener
I’m putting down deadener in the car and curious about where exactly you guys are putting it on/in the doors? Right behind the door card or?
Old Mar 3, 2020 | 02:06 PM
Route66Olds's Avatar
I use dynamat on the inside panel of the door skin. It helps give the door a nice solid sound when you shut it. It's easier to install if you cut it in half so you're not wrestling with the whole sheet (I cut it the long way). You could quarter it to make it even easier. Keep in mind that per the manufacturer you only need to cover 80% of the surface to make it effective. Be careful to leave any body trim holes open.
garys 68
Mar 31, 2020 05:58 AM
captmark
Dec 21, 2017 06:17 AM
outlawspeeder
Body work
May 16, 2013 08:34 AM
Danp76
Body work
Apr 13, 2012 01:07 PM
bobb
Body work
Oct 8, 2010 01:48 PM
