dashtop
can't figure out how to post pics
"go advanced" button below the std issue editing box lets you take up to 5 photos right from your computer.
They REALLY should have a CO-101 class here for How To Operate this thing.
see post #7 of
https://classicoldsmobile.com/forums...tml#post777664
see post #7 of
Is this what you're installing?
http://www.dashtop.com/products/dash...out-side-vents
Pictures would be great, as I was considering covering my cracked AC dash with a Non-AC cover.
Still trying to get the picture thing figured out, just haven't had time to sit down and go thru it. That's the same brand as mine. I'm pretty picky, not sure how it would show up in a pic. The worst part was the ac vents on each end. The hole for the adjuster louver is tight to begin with now your making it even smaller with the cover, not to mention the vents have square corners and the cover has round corners so I had to split the corners. In theory it's a great idea, they just had to put in a little more research for a product of better quality. It should be decent if you don't have the ac vents to mess with.
